5 Replies Latest reply on Apr 20, 2010 9:47 PM by bregent
    Uploading Dreamweaver files via FTP Client
    G-Rice1990
      Hello I have created a website using photshop that I then uploaded into dreamweaver create links. The website is about 25 files. I named the homepage of the website to index.html. Then I uploaded all the other files into there along with the images folder which contains all the slices created by photoshop. But when i go to the domain the screen is still blank white. Am I doing something wrong?
        • 1. Re: Uploading Dreamweaver files via FTP Client
          bregent Most Valuable Participant
          The most common reason is that you are uploading to the wrong directory.
          Can you show us your local and remote site definitions? What is the site url?
          • 2. Re: Uploading Dreamweaver files via FTP Client
            G-Rice1990 Level 1
            the site is http://www.carphonemobile.com/. Do you want me to give you the username and password
            to check it out for me?
            • 3. Re: Uploading Dreamweaver files via FTP Client
              No, not yet. Did your host instruct you to upload files to a specific directory, like public_html or something else?
              • 4. Re: Uploading Dreamweaver files via FTP Client
                G-Rice1990 Level 1
                here is everything the read me says:
                Your site http://www.carphonemobile.com was successfully created on  eu5.org server. Don't forget to check our terms.
                Be sure that your  account has minimum 1hit per month. Inactive accounts are deleted at the end of  month.
                New accounts have indexes disabled and anyone can see directory content until  you upload a valid index.  If indexes are disabled you will see a forbidden page (403) until you upload a  valid index.
                Valid indexes: index.html  index.php index.htm Index.php index.shtml  Index.htm Index.html default.htm default.html home.htm home.html
                Account Manager:
                You're hosted on eu5.org  server. Account Manager is  located at http://eu5org.freewebhostingarea.com/.
                Username: www.carphonemobile.com
                Password: password chosen by you at  registration
                If you have accounts created on more than one server, see http://www.freewebhostingarea.com/members/.
                Some scripts require server path. Yours is /home/vhosts/www.carphonemobile.com.
                Your Personal FTP Information:
                FTP server (host): eu5.org
                FTP username:  www.carphonemobile.com
                FTP password: it's equal with account password  chosen by you at registration
                To upload your files go to our Web based FTP client (recommended),  located at http://eu5org.freewebhostingarea.com/ftp/.
                Once logged in, you will be able to create a new  dir, new file, to upload a zip archive and have it unzipped automatically, to edit your files, to select files and download them as  .zip, to copy, move, delete, rename, chmod (change permissions), search anything under your account, ability to see  and edit dot files like .htaccess. With a normal ftp program you will not  be able to do this.
                For a complete list of features see http://eu5org.freewebhostingarea.com/ftp/help.html.
                MySQL database Information:
                You will get a limited number of free            databases per account. But you can create other accounts and get as many            free databases as you want.
                ATTENTION!!! MySQL databases must be activated @ Account  Manager >> Hit Create DB button.
                MySQL HostName is localhost only.            We don't allow external connections.
                phpMyAdmin is located at http://eu5org.freewebhostingarea.com/pma/. Log in using  MySQL username.
                PhpMyAdmin (PMA) is a tool that will help you to administer your database. You  don't have privileges to create a database with PMA because, as said before,  databases must be created @ Account Manager using            Create DB button.
                Database details (db name, username) will be provided at Account Manager once you create  the database.
                Other features at Account Manager:
                One click Autoinstaller for PhpBB3, SMF, WordPress, Joomla, Drupal (with Clean URLs preenabled), Moodle.
                One click database backup & One click database import
                Manage DB button (available after you create a database) >> then choose Backup DB or Import DB buttons
                Configure PHP
                you can turn on/off Register Globals, Magic  Quotes gpc, Allow_url_include variables.
                safe_mode is automatically  turned off few hours after account creation.
                Reset Account
                useful if you want to delete all  files/databases under your account.
                Fix Ownership
                some files are created with apache  permissions (e.g. unpack an archive, php scripts) and you're not able to  edit/delete them. This feature will fix permissions and you will be able to  manipulate all files under your account.
                • 5. Re: Uploading Dreamweaver files via FTP Client
                  I see a form script file in root directory that wasn't there earlier. How did you upload that?
