0 Replies Latest reply on Apr 21, 2010 4:35 AM by Jtromans
    Flex 4 Dynamic XML driven ComboBox [object Object] problem
    Jtromans
      I am dynamically populating a ComboBox with an HTTPservice calling an  XML file. This all works dandy through the Flash Build 4 interface.  Below is the ComboBox code:
      <s:ComboBox id="cbSockOptions" change="cbSockOptions_changeHandler(event)"
      selectedIndex="1"
      enabled="true"
      creationComplete="cbSockOptions_creationCompleteHandler(event)"
      labelField="Symbol">
      <s:AsyncListView list="{TypeUtility.convertToCollection(Operation1Result2.lastResult.Company)}"/>
      </s:ComboBox>
      As stated, above is my code which populates the ComboBox. I would  like to retrieve the seleted value from the ComboBox, but when I do I  get the following output (e.g. when presented in a Label):
      [object Company_Type]
      I am currently using the following code to retrieve the value of the  ComboBox
      cbSockOptions.selectedItem;
      All the reading I have done on the subject says that I must specify a  'labelField' in my ComboBox, which I do. However, I am still seeing the  [object Company_Type] as an output, instead of the real value.
      help!
