Hello,
I am using Captivate 4 and have imported several slides from powerpoint 03. When I publish to a .exe file, the first bullet animations work, but the subsequent bullet animations do not occur. When I watch inside the edit view in Captivate, all animations are working perfectly...it's only upon publishing to .exe for review. I'm concerned they won't play when published to LMS. My coworker said that she had seen something about this in Captivate 3, but to search the forums for an answer...I can't find one on here. I hope you can help, thank you!
NM, I figured it out! The menu button objects were set to pause, which was pausing my animations halfway through since the animations were longer from slide to slide.
