0 Replies Latest reply on Apr 21, 2010 8:53 AM by diwa130
    AIR problems on Linux
      I am using Flex on linux suse 64 bit without problems, however I have problems with AIR. I can run an air application generated
      in windows for instance, I can compile an air application using amxmlc, but when I try to run it using adl I get the following error:
      /usr/bin/javaclassname: Class file corrupt
         should be in a file called .class
      Also when I try to build AIR application using an IDE like IntellJIDEA or Netbeans, I have similar errors.
      Anyone has any clues about it ?
      Thank You,
