9 Replies Latest reply on Apr 22, 2010 3:11 AM by Jacob Bugge
    Very small design quality
    relzi1337
      Hey,
      I'm currently creating a design for contact lenses in the size of 14.8mm diameter.
      To see the design in a size it's easy to work on, I'm using 1200% zoom.
      Now, the thing is, when I'm zooming back to 100%, the design looks somewhat "blurry", and the colors become much lighter and everything becomes thinner in general.
      My question is, if printing this design in a professional printing house, which specialized in creating contact lenses, will the design look like shown @ 1200% zoom, or will it take the quality of the 100% zoom?
      Furthermore, the thickness of the lines/strokes, when changing from 1200% zoom to 100%, as mentioned, it becomes much thinner. If I want to get the outcome as shown in the 1200% zoom, should I make everything thicker, so when changing back to 100% it will look the same as in 1200%?
      My logic says it will look more similar to the way it looks on a 1200% zoom, due to high quality AI file, and the high quality machinery the company using to create the lenses.
      Moreover, if anyone has any experience in making graphics for a printing house, would appreciate any tips.
      Thanks in advanced.
        • 1. Re: Very small design quality
          Jacob Bugge MVP & Adobe Community Professional
          relzi,
          If you are zooming, everything should become very small at 100% and very hard to compare with the appearance at 1200%.
          If you are actually scaling, did you try ticking Scale Strokes & Effects in the Transform palette/panel flyout as James su´ggested in the other thread, and how did that effect things?
          • 2. Re: Very small design quality
            relzi1337 Level 1
            Hey Jacob,
            Yeah I did try that.. didn't see much of a change though.
            Here's a comparison between 100% and 1200%, for your consideration.
            • 3. Re: Very small design quality
              relzi,
              After seeing the image(s),
              That is quite expectable, given the resolution of the monitor.
              Like the 1200% zoom, presuming they know what they are doing.
              Again, expectable.
              It will.
              • 4. Re: Very small design quality
                relzi1337 Level 1
                So let me get it straight, because I got a bit confused by the answer:
                Should I base my design on the 1200% and leave everything as it is, or should I change the design so it will look on 100% the way I want it to look on 1200%?
                To simplify, if I want the design above to look like the 1200%, on the lens, should I change anything?
                Thanks.
                • 5. Re: Very small design quality
                  relzi,
                  No.
                  To feel more comfortable, you may print the design, or Save As PDF and print it from Acrobat/Reader.
                  If you use a standard Artboard = paper size, you should be able to see the rings much more clearly, depending on the printer resolution of course.
                  And you may set the Artboard size to 1/12 the paper size (for A4 that would be 17.5 x 24.75 mm) and Save As PDF, then print it on a normal size paper.
                  • 6. Re: Very small design quality
                    relzi1337 Level 1
                    Alrighty then!
                    Thank you very much, Sir.
                    • 7. Re: Very small design quality
                      Wade_Zimmerman Level 6
                      As for tips on printing list the specific questions you have so we can respond in kind.
                      Also can you show us a screen shot attaching it to your message with the camera icon in the tool bar of the message reply window of this forum.
                      I see you did already that soes look odd.
                      How did you compose the image that you posted? How did ou save it? I just want to make certaain we are seeing a good representation of what you are seeing.
                      • 8. Re: Very small design quality
                        relzi1337 Level 1
                        I took a screenshot of both states, and put them into one document in Photoshop.
                        • 9. Re: Very small design quality
                          You are welcome, relzi.
