0 Replies Latest reply on Apr 21, 2010 1:36 PM by flairjax
    Custom List sort not updating list skins
    flairjax Level 1
      I have a custom list component (see code below) that I do sorting on, but when I click a button to sort the list the UI/skin doesn't change.  The sort happens, but the skin is left as is, and it isn't until you mouse over an item in the list that the skin updates itself.
      package com.myapp.view.components
          import assets.style.skins.buttonbar.PlainButtonBarSkin;
          import flash.events.MouseEvent;
          import mx.collections.ICollectionView;
          import mx.collections.Sort;
          import mx.collections.SortField;
          import mx.events.StateChangeEvent;
          import mx.utils.ObjectUtil;
          import spark.components.ButtonBar;
          import spark.components.List;
          [SkinState("halfOpened")];
          [SkinState("fullyOpened")];
          [SkinState("collapsed")];
          public class CollapsibleSortableList extends List
              protected var _collapsed:Boolean = false;
              protected var _halfOpened:Boolean = true;
              protected var _fullyOpened:Boolean = false;
              //Declare the additional SkinStates
              [SkinPart(required="false")]
              public var sortButtonBar:ButtonBar;
              /*[SkinPart(required="true")]
              public var header:Button;*/
              private const SORT_ASCENDING:int = 0;
              private const SORT_DESCENDING:int = 1;
              private var _sorting:int = SORT_DESCENDING;
              private var _sort:Sort;
              private var _sortField:String = 'name';
              private var _dataSortField:SortField;
              private var _numericDataSort:Sort;
              private var _alphaSort:Sort;
              private var _dp:ICollectionView;
              public function CollapsibleSortableList()
                  super();
              //Add Event-Listeners to the textview for FocusEvent
              override protected function partAdded(partName:String, instance:Object):void {
                  super.partAdded(partName, instance);
                  if (instance == sortButtonBar) {
                      trace ("Adding sort button");
                      ButtonBar(instance).setStyle( 'skinClass', assets.style.skins.buttonbar.PlainButtonBarSkin );
                      ButtonBar(instance).addEventListener( MouseEvent.CLICK, sortButtonBar_changeHandler);
              //Clean up Event-Listeners and stuff...
              override protected function partRemoved(partName:String, instance:Object):void {
                  super.partRemoved(partName, instance);
                      trace ("Removing sort button");
                      ButtonBar(instance).removeEventListener(MouseEvent.CLICK, sortButtonBar_changeHandler);
              private function convertIPToInteger( val:Object ) : Number
                  var num:Number = 0;
                  var pattern:RegExp = /([0-9]+)\.([0-9]+)\.([0-9]+)\.([0-9]+)/;
                  if(val && val.ip != null){
                      var str:String = val.ip;
                      trace(pattern.exec(str));
                      var o:* = pattern.exec(str);
                  if( o == null ) { return num };
                  var p1:Number = parseInt(o[1]) * 16777216;
                  var p2:Number = parseInt(o[2]) * 65536;
                  var p3:Number = parseInt(o[3]) * 256;
                  var p4:Number = parseInt(o[4]) * 1;
                  num = p1 + p2 + p3 + p4;
                  return num;
              private function convertNetworkToInteger( val:Object ) : Number
                  var num:Number = 0;
                  var pattern:RegExp = /([0-9]+)\.([0-9]+)\.([0-9]+)\.([0-9]+)\/([0-9]+)/;
                  if(val && val.network != null){
                      var str:String = val.cloud;
                  var p1:Number = parseInt(o[1]) * 4294967296;
                  var p2:Number = parseInt(o[2]) * 16777216;
                  var p3:Number = parseInt(o[3]) * 65536;
                  var p4:Number = parseInt(o[4]) * 256;
                  var p5:Number = parseInt(0[5]) * 1
                  num = p1 + p2 + p3 + p4 + p5;
                  return num;
              private function ip_compareFunc( itemA:Object, itemB:Object ) : int
                  var valueA:Number = convertIPToInteger( itemA );
                  var valueB:Number = convertIPToInteger( itemB );
                  return ObjectUtil.numericCompare( valueA, valueB );
              private function network_compareFunc( itemA:Object, itemB:Object ) : int
                  var valueA:Number = convertNetworkToInteger( itemA );
                  var valueB:Number = convertNetworkToInteger( itemB );
                  if( itemA == itemB ) {
                      if( itemA.type == 'cloud' ){
                          return 1;
                      }else if( itemB.type == 'cloud' ) {
                          return -1;
              protected function sortButtonBar_changeHandler(event:*):void
                  var str:String = event.target.label as String;
                  str = str.toLowerCase();
                  this._sortField = str;
                  //sortList();
                  /* Create the SortField object for the correct field in the ArrayCollection object  */
                  _dataSortField = new SortField();
                  _dataSortField.name = _sortField;
                  if( str == 'name' ){
                      doAlphaSort();
                  }else if( str == 'ip' ){
                      _dataSortField.compareFunction = ip_compareFunc;
                      doSpecialSort();
                  }else{
                      _dataSortField.compareFunction = network_compareFunc;
                      doSpecialSort();
              private function doAlphaSort() : void
                  _dp = this.dataProvider as ICollectionView;
                  /* Create the Sort object and add the SortField object created earlier to the array of fields to sort on. */
                  _alphaSort = new Sort();
                  _alphaSort.fields = [_dataSortField];
                  /* Set the ArrayCollection object's sort property to our custom sort, and refresh the ArrayCollection. */
                  if (_dp != null)
                      if (this._sorting == SORT_ASCENDING)
                          this._alphaSort.reverse();
                          this._sorting = SORT_DESCENDING;
                      else
                          this._sorting = SORT_ASCENDING;
                      _dp.sort = this._alphaSort;
                      _dp.refresh();
              private function doNumericSort() : void
                  _dataSortField.numeric = true;
                  _numericDataSort = new Sort();
                  _numericDataSort.fields = [_dataSortField];
                  if (_dp != null)
                          this._numericDataSort.reverse();
                      else
                      _dp.sort = this._numericDataSort;
                      _dp.refresh();
              private function doSpecialSort() : void
                  if (_dp != null)
                      else
                      _dp.refresh();
              private function sortList():void
                  var dp:ICollectionView = this.dataProvider as ICollectionView;
                  this._sort = new Sort();
                  this._sort.fields = [new SortField(this._sortField)];
                  if (dp != null)
                          this._sort.reverse();
                      else
                      dp.sort = this._sort;
                      dp.refresh();
              //Gets called after invalidateSkinState() by Flex
              override protected function getCurrentSkinState():String {
                  if (_collapsed) {
                      this.dispatchEvent(new StateChangeEvent( StateChangeEvent.CURRENT_STATE_CHANGING, false, false, null, 'collapsed' ) );
                      return "collapsed";
                  }else if( _halfOpened ){
                      this.dispatchEvent(new StateChangeEvent( StateChangeEvent.CURRENT_STATE_CHANGING, false, false, null, 'halfOpened' ) );
                      return "halfOpened";
                  }else if( _fullyOpened ) {
                      this.dispatchEvent(new StateChangeEvent( StateChangeEvent.CURRENT_STATE_CHANGING, false, false, null, 'fullyOpened' ) );
                      return "fullyOpened";
                  }else{
                      return super.getCurrentSkinState();
