17 Replies Latest reply on Dec 17, 2014 8:36 PM by Delete Pattern By Name
    PS Script - Change Layer Color
    JForJeetu
      This Is My First Post Here, So Hello Everyone,
      Hope I Am Posting In The Right Section,
      I Have A Photoshop File Which Looks Like Shown Above..
      The Text 1 2 3 ...15 Are Different Layers..
      And The Boxes Are Different Layers, Named i1 i2 i3 ...... i15
      I Want To Write A Script That Will Change The Color Of Boxes (Actually This Is Legend Section For A Pie Chart)
      I Want To Write Very Hard-Coded Script, Nothing Dynamic,
      Like
      layer[i1].color = #9f13a8
      layer[i2].color = #520457
      layer[i3].color = #cc626c
      layer[i4].color = #aa5705
      I Tried Searching Around, But Very Less Help Available On ps-script And Complicated Examples....
      I Just Want Some Simple Lines, How To Easily Reference A Layer By Name And Change The Color (Forecolor, I Guess)
      I Wrote This But It Does Not Works
      var myDocument = app.activeDocument;
      var myLayer;
      myLayer=myDocument.artLayers.getByName("i1");
      myLayer.color="#9f13a8";
      I Don't Know If .artLayers Is Only For Text Layers Or Something.. I Found It In An Example...
        • 1. Re: PS Script - Change Layer Color
          Michael L Hale Level 5
          What kind of layers are the one with color?. Are they soild fill layers, shape layers, or just pixel layers where you made a selection and filled with color?
          • 2. Re: PS Script - Change Layer Color
            JForJeetu Level 1
            They Are Shape Layers..
            I Select The Layer, And Can Change Color With Paint-Bucket Tool
            • 3. Re: PS Script - Change Layer Color
              Good. Here is how to change the color of a fill or shape layer
              var sColor =  new SolidColor;
              sColor.rgb.hexValue = '9f13a8';
              app.activeDocument.activeLayer = app.activeDocument.layers.getByName("i1");
              setColorOfFillLayer( sColor );
              function setColorOfFillLayer( sColor ) {
                  var desc = new ActionDescriptor();
                      var ref = new ActionReference();
                      ref.putEnumerated( stringIDToTypeID('contentLayer'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                  desc.putReference( charIDToTypeID('null'), ref );
                      var fillDesc = new ActionDescriptor();
                          var colorDesc = new ActionDescriptor();
                          colorDesc.putDouble( charIDToTypeID('Rd  '), sColor.rgb.red );
                          colorDesc.putDouble( charIDToTypeID('Grn '), sColor.rgb.green );
                          colorDesc.putDouble( charIDToTypeID('Bl  '), sColor.rgb.blue );
                      fillDesc.putObject( charIDToTypeID('Clr '), charIDToTypeID('RGBC'), colorDesc );
                  desc.putObject( charIDToTypeID('T   '), stringIDToTypeID('solidColorLayer'), fillDesc );
                  executeAction( charIDToTypeID('setd'), desc, DialogModes.NO );
              • 4. Re: PS Script - Change Layer Color
                JForJeetu Level 1
                Thank You Very Much For Example Code..
                I Thought It Would Be Simple 2-3 Lines Code...
                Seems To Be Some Problem Though...
                I Get This Error.
                (I Am Using Photoshop CS4)
                Error 8800: General Photoshop error occurred. This functionality may not be available in this version of Photoshop.
                - The object "current fill layer" is not currently available.
                Line: 18
                ->      executeAction( charIDToTypeID('setd'), desc, DialogModes.NO );
                • 5. Re: PS Script - Change Layer Color
                  JForJeetu Level 1
                  I Can Use The Color-Code In RGB Format, If That Could Make Things Easier...
                  • 6. Re: PS Script - Change Layer Color
                    Although you can set the color either by hexValue or by R, G, and B values, it would not really be easier either way. And it would not fix the error.
                    I think the error is because the layer named "i1" is not a fill or shape layer. Try this code
                    alert( app.activeDocument.activeLayer.kind );// should be LayerKind.SOLIDFILL
                    If the alert does not say LayerKind.SOLIDFILL the layer is not a fill layer.
                    • 7. Re: PS Script - Change Layer Color
                      If the layer is an artLayer ( just pixels ) you can change the color like this.
                      app.activeDocument.selection.selectAll();
                      app.activeDocument.selection.fill( sColor, undefined, undefined, true );
                      app.activeDocument.selection.deselect();
                      • 8. Re: PS Script - Change Layer Color
                        JForJeetu Level 1
                        Ok, It Was An artLayer...
                        Your Last Piece Of Code Worked...
                        Thank You Very Very Much For Your Help...
                        • 9. Re: PS Script - Change Layer Color
                          GDrider77
                          This works great, and almost does what i want, i would like to expand upon this by using the color picker to set the colors, rather than declaring them in the code. Is this possible?
                          I found this handy color picker script on ps-sripts, which was actually from here somewhere. Is this something that could be tied into this?
                          http://www.ps-scripts.com/bb/viewtopic.php?f=13&t=2886&sid=04726f28d56f823e757c4afaf957ca4 c
                          Hopefully this all makes sense. I basically have a file, that i have to 3-5 times a day, open up and change the color palette on it. It has 7 colors that need to change quite often, but its much easier to use the color picker during the process, rather than using it then updating the js file, then running it on the template.
                          Thanks.
                          Ryan
                          • 10. Re: PS Script - Change Layer Color
                            dserodio Level 1
                            Using this script, on some layers the "Fill" dialog pops-up and I have to hit OK to confirm, on other layers this dialog doesn't open and the color is applied right away. What could cause this difference?
                            • 11. Re: PS Script - Change Layer Color
                              Thank you so much Michael.
                              • 12. Re: PS Script - Change Layer Color
                                Delete Pattern By Name Level 1
                                Hey Michael
                                I want to apply pattern to solid layer as same as we applied color. Can you please help me with this.
                                • 13. Re: Re: PS Script - Change Layer Color
                                  Chuck Uebele Adobe Community Professional & MVP
                                  If you want to apply a pattern you can use scriptlistener to generate the code. It might be best to create the shape first by either drawing it or by using scriptlistener to generate the code, then use scriptlistener to generate code to change the fill pattern. This way you can use that code for any type of shape layer: oval, rectangle, etc. If you don't want a dialog box, you will have to find both the name and id number for the pattern used - again, this will show up using scriptlistener. If you want have a dialog box come up and be able to select which pattern you want to use, change the last line of the scriptlistener code to:
                                  executeAction( idsetd, desc10, DialogModes.ALL );
                                  But be sure to reset the dialog mode to No after that line. Here's an example of the code for changing a pattern:
                                  #target photoshop
                                  var idsetd = charIDToTypeID( "setd" );
                                      var desc10 = new ActionDescriptor();
                                      var idnull = charIDToTypeID( "null" );
                                          var ref2 = new ActionReference();
                                          var idcontentLayer = stringIDToTypeID( "contentLayer" );
                                          var idOrdn = charIDToTypeID( "Ordn" );
                                          var idTrgt = charIDToTypeID( "Trgt" );
                                          ref2.putEnumerated( idcontentLayer, idOrdn, idTrgt );
                                      desc10.putReference( idnull, ref2 );
                                      var idT = charIDToTypeID( "T  " );
                                          var desc11 = new ActionDescriptor();
                                          var idPtrn = charIDToTypeID( "Ptrn" );
                                              var desc12 = new ActionDescriptor();
                                              var idNm = charIDToTypeID( "Nm  " );
                                              desc12.putString( idNm, """$$$/Presets/Patterns/Patterns_pat/TieDye=Tie Dye""" );//pattern name
                                              var idIdnt = charIDToTypeID( "Idnt" );
                                              desc12.putString( idIdnt, """1b29876b-58b7-11d4-b895-a898787104c1""" );//pattern ID number
                                          desc11.putObject( idPtrn, idPtrn, desc12 );
                                      var idpatternLayer = stringIDToTypeID( "patternLayer" );
                                      desc10.putObject( idT, idpatternLayer, desc11 );
                                  executeAction( idsetd, desc10, DialogModes.ALL );//Change the NO to ALL
                                  app.displayDialogs = DialogModes.NO;//Make sure you reset!!!
                                  • 14. Re: Re: PS Script - Change Layer Color
                                    Thank you for your prompt help.
                                    Layer type is PsLayerKind.psNormalLayer.
                                    I tried your code, but it gives me below error.
                                    • 15. Re: Re: PS Script - Change Layer Color
                                      Yes, my script is only for applying a pattern to a shape layer. if you want to do it to a normal pixel layer, you would need to make a selection, then use the fill pattern command, which you can also do by using scriptlistener.
                                      • 16. Re: Re: PS Script - Change Layer Color
                                        Thank you sir.
                                        I created a new fill pattern layer. And it is working.
                                        • 17. Re: PS Script - Change Layer Color
                                          I want to apply different colors and patterns to a cloth in an image. E.g. color of a shirt, pant, collar etc.
                                          Would you please suggest me how to automatize this concept.
