5 Replies Latest reply on Nov 14, 2010 8:23 AM by Disc7
    FB4 launch failed file not found file:/C:/xxxx
    vanderhoffer
      hi All,
      I know there have been a few threads about this before but having no luck in finding answer.
      Config
      Win XP sp2
      Eclipse 3.5.2
      flash builder 4 (build272416) plugin
      new->flex project
      flex 4.0 sdk
      default settings
      when I do a run or debug as web ap I get launch failed file not found and the correct file displayed ie file:/c:/myapp/myapp.html
      Flex builder 3, run as flex app worked like a dream, this is nightmare
      thx
      Art
        • 1. Re: FB4 launch failed file not found file:/C:/xxxx
          levancho Level 3
          open Run/Debug Configuration ...
          it is the link upder  Run/Debug context menu,
          you probably have incorrect app url specified there.
          • 2. Re: FB4 launch failed file not found file:/C:/xxxx
            vanderhoffer Level 1
            levancho, I assume you are reffeing to selecting the app that was created ubder the run/debug configuration menu, if so then yes it is the correct app.
            to create the run/debug profile
            web application
            project name -> testflex
            Application file -> src/testflex.mxml
            URL or path to lauch ->use default c:/myapp/testmyflex/testfex.html
            common tab -> save as ->local
            run as -> testflex (web application)
            launch failed, file not found file:/C:/myapp/flextest.html
            run as -> web application
            if I change
            to
            URL or path to lauch ->use default c:/myapp/src/testfex.xmxl
            flash player standalone will open but no swf file is generated, the .css is generated and placed in the testmyflex folder
            Art
            • 3. Re: FB4 launch failed file not found file:/C:/xxxx
              Jason San Jose Adobe Employee
              Did your project actually compile? In Flash Builder, what do you see in your bin-debug folder? If your project is called "myapp", using the default settings, you should have c:\myapp\bin-debug with myapp.html and myapp.swf. Do you have Build Automatically turned on (in the Project menu)?
              Jason San Jose
              Software Engineer, Flash Builder
              • 4. Re: FB4 launch failed file not found file:/C:/xxxx.html
                JoseAjáAjá Level 1
                Hi.
                I'm having the same problem. I'm using Flex Builder 3, and, all of the sudden, my application stopped compiling. Flex builder won't create neither the HTML wrapper, nor the swf file (I have the "Build automatically" option checked, BTW).
                Plus, several "Invalid embed directive in stylesheet..." errors appeared.
                I keep checking everyfile, every filepath, and all of them are there, and aren't corrupted.
                The only thing that I can think of that could have messed with my Flex is that I installed Adobe Captivate CS5 yesterday... Could that be the root of the problem??? Can't I used both programs????
                Thx!
                • 5. Re: FB4 launch failed file not found file:/C:/xxxx
                  Disc7
                  Was looking for a solution for this and found it by switching the Flex SDK from 3.2 to 4. HTML wrapper now builds. Refused to build when it was set to 3.2 for any new project in Flash builder pro 4 on Windows 7 64bit.
