5 Replies Latest reply on May 3, 2010 12:25 PM by Ray Bakker
    CF Builder won't connect to Coldfusion 9 through RDS
    Ray Bakker
      Greeting
      I have download the trial version of CF Builder and have CF 9  Dev Edition on my XP SP3. I also have Dreamweaver CS4 installed. Dreamweaver can talk to CF through RDS however, CF Builder does not. I get a 503 error. Yes, the service is running. Any thoughts?
        • 1. Re: CF Builder won't connect to Coldfusion 9 through RDS
          Ray Bakker Level 1
          More info:
          I set CF Builder to auto start and auto stop CF 9. Here is want appears in the Console window during start up:
          [localhost]:Starting Macromedia JRun 4.0 (Build 108795), coldfusion server
          [localhost]:These changes should get picked up!
          [localhost]:22/04 10:54:31 warning Unable to open C:\ColdFusion9\runtime/lib/license.properties
          [localhost]:22/04 10:54:32 info JRun Naming Service listening on *:2932
          [localhost]:22/04 10:54:34 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
          [localhost]:22/04 10:54:34 info JRun Web Server listening on *:8500
          [localhost]:22/04 10:54:34 info Deploying enterprise application "Adobe_ColdFusion_9" from: file:/C:/ColdFusion9/
          [localhost]:22/04 10:54:35 info Deploying web application "Adobe ColdFusion 9" from: file:/C:/ColdFusion9/
          [localhost]:22/04 10:54:38 INFO License Service: Flex 1.5 CF Edition enabled
          [localhost]:22/04 10:54:38 INFO Starting Flex 1.5 CF Edition
          [localhost]:22/04 10:54:38 user JSPServlet: init
          [localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: init
          [localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: ColdFusion: Starting application services
          [localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: ColdFusion: VM version = 14.0-b16
          [localhost]:04/22 10:54:39 Information [main] - Starting logging...
          [localhost]:04/22 10:54:39 Information [main] - Starting license...
          [localhost]:04/22 10:54:43 Information [main] - Invalid ColdFusion 9 license.
          [localhost]:04/22 10:54:43 Information [main] - Developer Edition enabled
          [localhost]:04/22 10:54:43 Information [main] - Starting crypto...
          [localhost]:04/22 10:54:43 Information [main] - Installed JSafe JCE provider: Version 3.6 RSA Security Inc. Crypto-J JCE Security Provider (implements RSA, DSA, Diffie-Hellman, AES, DES, Triple DES, DESX, RC2, RC4, RC5, PBE, MD2, MD5, RIPEMD160, SHA1, SHA224, SHA256, SHA384, SHA512, HMAC-MD5, HMAC-RIPEMD160, HMAC-SHA1, HMAC-SHA224, HMAC-SHA256, HMAC-SHA384, HMAC-SHA512)
          [localhost]:04/22 10:54:43 Information [main] - Starting security...
          [localhost]:04/22 10:54:44 Information [main] - Starting scheduler...
          [localhost]:04/22 10:54:44 Information [main] - Starting WatchService...
          [localhost]:04/22 10:54:44 Information [main] - Starting debugging...
          [localhost]:04/22 10:54:44 Information [main] - Starting sql...
          [localhost]:04/22 10:54:44 Information [main] - Pool Manager Started
          [localhost]:04/22 10:54:44 Information [main] - Starting mail...
          [localhost]:04/22 10:54:44 Information [main] - Starting runtime...
          [localhost]:04/22 10:54:44 [main] INFO Using "C:\DOCUME~1\rbakker\LOCALS~1\Temp\vfs_cache" as temporary files store.
          [localhost]:04/22 10:54:44 Information [main] - CORBA Configuration not enabled
          [localhost]:04/22 10:54:44 Information [main] - Starting cron...
          [localhost]:04/22 10:54:44 Information [main] - Starting registry...
          [localhost]:04/22 10:54:45 Information [main] - Starting client...
          [localhost]:04/22 10:54:46 Information [main] - Starting xmlrpc...
          [localhost]:04/22 10:54:47 Information [main] - Starting graphing...
          [localhost]:04/22 10:54:47 Information [main] - Starting verity...
          [localhost]:04/22 10:54:47 Information [main] - Starting solr...
          [localhost]:04/22 10:54:47 Information [main] - Starting archive...
          [localhost]:04/22 10:54:47 Information [main] - Starting document...
          [localhost]:04/22 10:54:47 Information [main] - Starting eventgateway...
          [localhost]:04/22 10:54:47 Information [main] - Starting Event Backend Handlers.
          [localhost]:04/22 10:54:47 Information [main] - Initialized EventRequestDispatcher with a Thread Pool size of 1.
          [localhost]:04/22 10:54:47 Information [main] - Initializing EventRequestHandler
          [localhost]:04/22 10:54:47 Information [main] - Starting Event Gateways.
          [localhost]:04/22 10:54:47 Information [main] - Starting FlexAssembler...
          [localhost]:04/22 10:54:47 Information [main] - Starting .NET...
          [localhost]:04/22 10:54:47 Information [main] - Starting Monitoring...
          [localhost]:04/22 10:54:47 Information [main] - ColdFusion started
          [localhost]:22/04 10:54:47 user ColdFusionStartUpServlet: ColdFusion: application services are now available
          [localhost]:22/04 10:54:47 user CFMxmlServlet: init
          [localhost]:22/04 10:54:47 INFO Macromedia Flex Build: 87315.134646
          [localhost]:22/04 10:54:47 user CFMxmlServlet: Macromedia Flex Build: 87315.134646
          [localhost]:22/04 10:54:50 user CFSwfServlet: init
          [localhost]:22/04 10:54:50 user CFCServlet: init
          [localhost]:22/04 10:54:51 user FlashGateway: init
          [localhost]:22/04 10:54:51 user MessageBrokerServlet: init
          [localhost]:22/04 10:54:52 user CFFormGateway: init
          [localhost]:22/04 10:54:52 user CFInternalServlet: init
          [localhost]:22/04 10:54:53 user WSRPProducer: init
          [localhost]:22/04 10:54:53 user ServerCFCServlet: init
          [localhost]:Server coldfusion ready (startup time: 26 seconds)
          [localhost]:Error(04/22 at 10:57:24) Unable to start server. Server startup timed out.
          [localhost]:Error(04/22 at 10:57:29) Operation is canceled.
          It seems to fail when it is trying initialize the RDSServlet. Any thoughts? Wrong version of Java?
          • 2. Re: CF Builder won't connect to Coldfusion 9 through RDS
            SpiderFromMars
            I am having the same issue on Windows 7. Dreamweaver connects to RDS without error but CFB doesn't.
            • 3. Re: CF Builder won't connect to Coldfusion 9 through RDS
              Ray Bakker Level 1
              I brought my laptop home and found I was able to connect to my localhost via RDS. I turned off my proxy/network filter server and it worked perfectly. Are you woking on a standalone pc/laptop or one that is on a network?
              Hope that helps.
              • 4. Re: CF Builder won't connect to Coldfusion 9 through RDS
                SpiderFromMars Level 1
                Hi Ray,
                Thanks for the reply!
                I am on a standalone pc, so i don't know how a proxy/network filter would come into play.
                Where do I find those settings?
                Thanks again!
                • 5. Re: CF Builder won't connect to Coldfusion 9 through RDS
                  Ray Bakker Level 1
                  Thin White Duke
                  Sorry, I suspect that our Group Policy had something to do with restricting the start up of the RDS Servlet. Maybe something in your firewall/router software? I have not had a chance to talk  to our network people yet.
                  In IE - tools > internet options > Connections (tab) > LAN settings (button) > Proxy server ( uncheck)
                  I hope that helps.
