1 Reply Latest reply on Apr 22, 2010 12:03 PM by matthew horn
    updating data for a chart
    JockMahon Level 1
      I have the following example , when the NS value changes the
      chart  does not update. If the refresh is put back in then it works. Is this normal or is it the way iv done it. also how would this
      work if the data provider was in a model object. ie the data was updating automaticallywithout user interaction. would i have to still call the refresh
      from somewhere
               xmlns:mx="library://ns.adobe.com/flex/mx"
               width="100%" height="100%">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  private var tmp:uint = 10;
                  [Bindable]
                  private var orders:ArrayCollection = new ArrayCollection( [
                      { Supplier: tmp    , Orders: tmp } ]);
                  protected function ssd_changeHandler(event:Event):void
                      orders.getItemAt(0).Orders = ssd.value;
                      //orders.refresh();
          </fx:Script>
          <s:layout>
              <s:VerticalLayout/>
          </s:layout>
          <mx:ColumnChart id="column"
                          height="50%"
                          width="50%"
                          paddingLeft="5"
                          paddingRight="5"
                          showDataTips="true"
                          dataProvider="{orders}"  >
              <mx:horizontalAxis>
                  <mx:CategoryAxis categoryField="Supplier"/>
              </mx:horizontalAxis>
              <mx:series>
                  <mx:ColumnSeries
                      xField="Supplier"
                      yField="Orders"
                      displayName="Orders"/>
              </mx:series>
          </mx:ColumnChart>
          <s:NumericStepper id="ssd" value="10" maximum="100" change="ssd_changeHandler(event)"/>
      </s:Application>
