I've come across a vexing problem. When launching FB4, before anything else displays, I get the error message:
The log states at the beginning of the 740K .log:
!ENTRY org.eclipse.core.resources 4 568 2010-04-21 15:35:26.975
!MESSAGE Could not write metadata for '/'.
!STACK 0
java.io.FileNotFoundException: /Users/vchan/Documents/Adobe Flash Builder 4/.metadata/.plugins/org.eclipse.core.resources/.root/.markers.snap (No such file or directory)
at java.io.FileOutputStream.openAppend(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
at org.eclipse.core.internal.localstore.SafeChunkyOutputStream.<init>(SafeChunkyOutputStream.java:43)
at org.eclipse.core.internal.localstore.SafeChunkyOutputStream.<init>(SafeChunkyOutputStream.java:39)
at org.eclipse.core.internal.resources.SaveManager.visitAndSnap(SaveManager.java:1512)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:1049)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:991)
at org.eclipse.core.internal.resources.DelayedSnapshotJob.run(DelayedSnapshotJob.java:44)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.core.resources 4 566 2010-04-21 17:26:29.501
!MESSAGE Could not save master table to file '/Users/vchan/Documents/Adobe Flash Builder 4/.metadata/.plugins/org.eclipse.core.resources/.safetable/org.eclipse.core.resources'.
!STACK 0
java.io.FileNotFoundException: /Users/vchan/Documents/Adobe Flash Builder 4/.metadata/.plugins/org.eclipse.core.resources/.safetable/org.eclipse.core.resources (No such file or directory)
at org.eclipse.core.internal.resources.SaveManager.saveMasterTable(SaveManager.java:1109)
at org.eclipse.core.internal.resources.SaveManager.saveMasterTable(SaveManager.java:1102)
at org.eclipse.core.internal.resources.SaveManager.save(SaveManager.java:1079)
and the last bit at the end:
!ENTRY org.eclipse.osgi 2 0 2010-04-22 11:20:22.765
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-04-22 11:20:22.766
!MESSAGE Bundle reference:file:plugins/org.eclipse.ui.carbon.nl1_3.5.0.v20091121043401.jar was not resolved.
!SUBENTRY 2 org.eclipse.ui.carbon.nl1_3.5.0.v20091121043401 2 0 2010-04-22 11:20:22.766
!MESSAGE Missing host org.eclipse.ui.carbon_[0.0.0,9.0.0).
!ENTRY org.eclipse.osgi 2 0 2010-04-22 11:20:22.768
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-04-22 11:20:22.768
!MESSAGE Bundle org.eclipse.ui.carbon.nl1_3.5.0.v20091121043401_3.5.0.v20091121043401 [312] was not resolved.
!SUBENTRY 2 org.eclipse.ui.carbon.nl1_3.5.0.v20091121043401 2 0 2010-04-22 11:20:22.769
I would be happy to provide the log file to anyone who is familiar with this issue (I am not). I'm already 25% as productive without FB. Please help.
regards,
- Victor
I've replied here: http://forums.adobe.com/thread/622729?tstart=0
Not sure if it'll cure your problem, but worth a try.
Some more details: running OS X 10.5.7. This is what the Apple Crash reporter lists in addition to the log info:
Process: Adobe Flash Builder 4 [6614]
Path: /Users/vchan/Applications/_dev/Adobe Flash Builder 4/Adobe Flash Builder 4.app/Contents/MacOS/Adobe Flash Builder 4
Identifier: org.eclipse.eclipse
Version: 4.0.0.272416 (4.0.0.272416)
Code Type: X86 (Native)
Parent Process: launchd [646]
Interval Since Last Report: 12570 sec
Crashes Since Last Report: 3
Per-App Interval Since Last Report: 96 sec
Per-App Crashes Since Last Report: 3
Date/Time: 2010-04-22 14:13:21.445 -0400
OS Version: Mac OS X 10.5.7 (9J61)
Report Version: 6
Anonymous UUID: 6B7FC4F4-B911-488B-8657-92BD978237F5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0
Application Specific Information:
Java information:
Version: Java HotSpot(TM) Client VM (1.5.0_16-133 mixed mode)
Virtual Machine version: Java HotSpot(TM) Client VM (1.5.0_16-133) for macosx-x86, built on Aug 27 2008 11:00:20 by root with gcc 4.0.1 (Apple Inc. build 5465)
Exception type: Bus Error (0xa) at pc=0x0045befb
Current thread (0x210015d0): JavaThread "main" [_thread_in_vm, id=-1607567584]
Stack: [0xbf800000,0xc0000000)
Java Threads: ( => current thread )
0x21008ff0 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8503296]
0x210085e0 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8496640]
0x21008160 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8483328]
0x21007820 JavaThread "Finalizer" daemon [_thread_blocked, id=8493056]
0x21007440 JavaThread "Reference Handler" daemon [_thread_blocked, id=8486912]
=>0x210015d0 JavaThread "main" [_thread_in_vm, id=-1607567584]
Other Threads:
0x21006b90 VMThread [id=8467968]
0x21009b30 WatcherThread [id=8506880]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 18176K, used 1560K [0x25580000, 0x26930000, 0x27ce0000)
eden space 16192K, 3% used [0x25580000, 0x25605178, 0x26550000)
from space 1984K, 51% used [0x26740000, 0x26840fd0, 0x26930000)
to space 1984K, 0% used [0x26550000, 0x26550000, 0x26740000)
tenured generation total 241984K, used 6672K [0x27ce0000, 0x36930000, 0x45580000)
the space 241984K, 2% used [0x27ce0000, 0x28364288, 0x28364400, 0x36930000)
compacting perm gen total 65536K, used 11968K [0x45580000, 0x49580000, 0x55580000)
the space 65536K, 18% used [0x45580000, 0x461303c0, 0x46130400, 0x49580000)
No shared spaces configured.
Virtual Machine arguments:
JVM args: -Xms256m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m -Xdock:name=Flash Builder -Xdock:icon=../Resources/fb_app.icns -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.noFocusRing -Dorg.eclipse.swt.internal.carbon.smallFonts
Java command: <unknown>
launcher type: generic
Thread 0 Crashed:
0 libjvm.dylib 0x0045befb 0x3b9000 + 667387
1 libjvm.dylib 0x005c8117 JNI_CreateJavaVM_Impl + 101959
2 libswt-carbon-3555.jnilib 0x5ca8ef40 callback + 855
3 ??? 0x5cb1d098 0 + 1555157144
4 com.apple.HIToolbox 0x923bc11d DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
5 com.apple.HIToolbox 0x923bb55b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
6 com.apple.HIToolbox 0x923bb3c0 SendEventToEventTargetWithOptions + 58
7 com.apple.HIToolbox 0x923e9d34 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 356
8 com.apple.HIToolbox 0x923bc4d6 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
9 com.apple.HIToolbox 0x923bb55b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
10 com.apple.HIToolbox 0x923d7eac SendEventToEventTarget + 52
11 com.apple.HIToolbox 0x92444a4c ToolboxEventDispatcher + 86
12 com.apple.HIToolbox 0x92497b28 GetOrPeekEvent + 399
13 com.apple.HIToolbox 0x92497931 GetNextEventMatchingMask + 489
14 com.apple.HIToolbox 0x9249760e WNEInternal + 151
15 com.apple.HIToolbox 0x9249756d WaitNextEvent + 54
16 com.apple.HIToolbox 0x924962a9 ModalDialog + 883
17 com.apple.HIToolbox 0x924cc87e RunStandardAlert + 776
18 eclipse_1206.so 0x0001b3ba displayMessage + 286
19 eclipse_1206.so 0x000169e8 run + 6559
20 org.eclipse.eclipse 0x000024aa original_main + 1782
21 org.eclipse.eclipse 0x00002b96 main + 1517
22 org.eclipse.eclipse 0x00001c10 _start + 210
23 org.eclipse.eclipse 0x00001b3d start + 41
Thread 1:
0 libSystem.B.dylib 0x92f6a286 mach_msg_trap + 10
1 libSystem.B.dylib 0x92f71a7c mach_msg + 72
2 libSystem.B.dylib 0x92fdf12f mach_msg_server + 491
3 libjvm.dylib 0x003c7b85 0x3b9000 + 60293
4 libjvm.dylib 0x003c7945 0x3b9000 + 59717
5 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
6 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 2:
2 libjvm.dylib 0x004d11b3 0x3b9000 + 1147315
3 libjvm.dylib 0x004d104c 0x3b9000 + 1146956
4 libjvm.dylib 0x00415dcd 0x3b9000 + 380365
5 libjvm.dylib 0x00415937 0x3b9000 + 379191
6 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
7 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 3:
2 libjvm.dylib 0x004d126a 0x3b9000 + 1147498
3 libjvm.dylib 0x00416e6a 0x3b9000 + 384618
4 libjvm.dylib 0x00416455 0x3b9000 + 382037
5 libjvm.dylib 0x005f7ee1 JVM_MonitorWait + 465
6 ??? 0x235859b1 0 + 592992689
7 ??? 0x2357f9d3 0 + 592968147
8 ??? 0x2357f9d3 0 + 592968147
9 ??? 0x2357d227 0 + 592957991
10 libjvm.dylib 0x004d228a 0x3b9000 + 1151626
11 libjvm.dylib 0x00416343 0x3b9000 + 381763
12 libjvm.dylib 0x00416235 0x3b9000 + 381493
13 libjvm.dylib 0x00416175 0x3b9000 + 381301
14 libjvm.dylib 0x00416098 0x3b9000 + 381080
15 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
16 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 4:
8 ??? 0x2357faaa 0 + 592968362
9 ??? 0x2357faaa 0 + 592968362
10 ??? 0x2357d227 0 + 592957991
11 libjvm.dylib 0x004d228a 0x3b9000 + 1151626
12 libjvm.dylib 0x00416343 0x3b9000 + 381763
13 libjvm.dylib 0x00416235 0x3b9000 + 381493
14 libjvm.dylib 0x00416175 0x3b9000 + 381301
15 libjvm.dylib 0x00416098 0x3b9000 + 381080
16 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
17 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 5:
0 libSystem.B.dylib 0x92f6a2c2 semaphore_wait_trap + 10
1 libjvm.dylib 0x0041764e 0x3b9000 + 386638
2 libjvm.dylib 0x00417245 0x3b9000 + 385605
3 libjvm.dylib 0x00416098 0x3b9000 + 381080
4 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
5 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 6:
3 libjvm.dylib 0x004d0f09 0x3b9000 + 1146633
4 libjvm.dylib 0x00417c7b 0x3b9000 + 388219
5 libjvm.dylib 0x00417958 0x3b9000 + 387416
6 libjvm.dylib 0x00416098 0x3b9000 + 381080
7 libjvm.dylib 0x0067d935 JVM_RaiseSignal + 441077
8 libSystem.B.dylib 0x92fe6200 _pthread_body + 27
Thread 7:
4 libjvm.dylib 0x00417d90 0x3b9000 + 388496
Thread 8:
3 libjvm.dylib 0x004185af 0x3b9000 + 390575
4 libjvm.dylib 0x004180fa 0x3b9000 + 389370
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x005c8061 ecx: 0x21001690 edx: 0x00000000
edi: 0x210015d0 esi: 0xbfffeaa8 ebp: 0xbfffea78 esp: 0xbfffea78
ss: 0x0000001f efl: 0x00010246 eip: 0x0045befb cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x3fff +org.eclipse.eclipse 4.0.0.272416 (4.0.0.272416) /Users/vchan/Applications/_dev/Adobe Flash Builder 4/Adobe Flash Builder 4.app/Contents/MacOS/Adobe Flash Builder 4
0x13000 - 0x1bffe +eclipse_1206.so ??? (???) /Users/vchan/Applications/_dev/Adobe Flash Builder 4/plugins/org.eclipse.equinox.launcher.carbon.macosx_1.0.200.v20090520-1835/eclipse_1206.so
0x27000 - 0x2dffd com.apple.JavaVM 12.2.2 (12.2.2) <9ad39149cc7ecc91da3e93df7f61d315> /System/Library/Frameworks/JavaVM.framework/JavaVM
0x45000 - 0x4cfe0 libverify.dylib ??? (???) <7cc184265a20ef60af782f48077e2131> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libverify.dylib
0x52000 - 0x58fff JavaNativeFoundation ??? (???) <fd9995f2d5028539d72a2567904d4f10> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x67000 - 0x81fef libjava.jnilib ??? (???) <a0c0a3c0e67c4e2d52fd49257e94410e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjava.jnilib
0x8f000 - 0x9affb libzip.jnilib ??? (???) <cf0c5694f94ecb552e54776fb2b3f50b> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libzip.jnilib
0x3b9000 - 0x708ffb libjvm.dylib ??? (???) <1c388ad24330d93a9d0e346861b85860> /System/Library/Frameworks/JavaVM.framework/Versions/CurrentJDK/Libraries/libjvm.dylib
0x57fb8000 - 0x57fc3ffb libnet.jnilib ??? (???) <f122ecb062b6468d85b88b1eb7ca78f5> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnet.jnilib
0x57fca000 - 0x57fcdffc libnio.jnilib ??? (???) <5901461c85f4abfd8209cf8bf84732e2> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnio.jnilib
0x5aac6000 - 0x5accdfef com.apple.RawCamera.bundle 2.0.15 (471) <557c94fbd7c15219746393464a79cf87> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x5ca8c000 - 0x5ca8efff +libswt-carbon-3555.jnilib ??? (???) <b899b0e787eef33aada4ee03144e5a86> /Users/vchan/Applications/_dev/Adobe Flash Builder 4/configuration/org.eclipse.osgi/bundles/292/1/.cp/libswt-carbon-3555.jnilib
0x5ca93000 - 0x5cac9fff +libswt-pi-carbon-3555.jnilib ??? (???) <c34d379a1a03cff6c56d653bb1a52c9f> /Users/vchan/Applications/_dev/Adobe Flash Builder 4/configuration/org.eclipse.osgi/bundles/292/1/.cp/libswt-pi-carbon-3555.jnilib
0x5caff000 - 0x5cb01ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
0x5d03f000 - 0x5d043ff3 +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.7d8) <441140269012a03a2c9a7ac35776cf95> /Users/vchan/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x5d048000 - 0x5d069fef +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <79b18344ec6899c6d8242bc5ffe7bcd9> /Users/vchan/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x5d194000 - 0x5d1b4fff +Cocoa Patcher ??? (???) <3fb09362b8abac7dff5703b34d22c38f> /Users/vchan/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <b0ea42e222a36a182e4ea30c3d71ce68> /usr/lib/dyld
0x90b36000 - 0x90b42ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90ccb000 - 0x90d0cfe7 libRIP.A.dylib ??? (???) <69bd09fcd8d8b235cee7a405290d6818> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90d0d000 - 0x90d1afe7 com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90d1b000 - 0x90d6cff7 com.apple.HIServices 1.7.0 (???) <74c3d19e3981d6999630ec516681f079> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x90d6d000 - 0x90d95ff7 com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x90d96000 - 0x90e29ff3 com.apple.ApplicationServices.ATS 3.7 (???) <a535fc4982d3acff6530ec25c402e679> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90e2a000 - 0x90e3afff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <7bd1ec22c47e62a11b34d7ba66606e2e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x90e3b000 - 0x90eb8feb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <5a4e6329f8dbca5dcd70924525afd24a> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x90eb9000 - 0x90eb9ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90eba000 - 0x90edefff libxslt.1.dylib ??? (???) <ec4c269815bab8e7211cb8fe9df3a9a3> /usr/lib/libxslt.1.dylib
0x90f14000 - 0x90fa7fff com.apple.ink.framework 101.3 (86) <dfa9debcd7537849d228021d1d9c0f63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90fa8000 - 0x90fa8ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x90fa9000 - 0x90fb2fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <6a6518b392d3d41ace3dcea69d6809d9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x90fb3000 - 0x90fb4ffc libffi.dylib ??? (???) <596e0dbf626b211741cecaa9698f271b> /usr/lib/libffi.dylib
0x90fb5000 - 0x91095fff libobjc.A.dylib ??? (???) <bba0c22add60c7724e259ab28de8953e> /usr/lib/libobjc.A.dylib
0x91096000 - 0x9115dff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9115e000 - 0x9119cfff libGLImage.dylib ??? (???) <a6425aeb77f4da13212ac75df57b056d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9119d000 - 0x911dffef com.apple.NavigationServices 3.5.2 (163) <26eeb5a205f749aad83d5dac0330c41f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x911e0000 - 0x911e0fff com.apple.Carbon 136 (136) <ec1d4184925e652dbe1b9200a5a552ec> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x911e1000 - 0x914bbff3 com.apple.CoreServices.CarbonCore 786.11 (786.13) <9e2d85d52e5e2951aa4dd53c48ccc52f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x914bc000 - 0x914c6feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <caa41909dcb5a18a94bc68cd13999bd5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x914d3000 - 0x914dbfff com.apple.DiskArbitration 2.2.1 (2.2.1) <d97688958e0b1fdcd4747088bdf1962a> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x914dc000 - 0x914dcff8 com.apple.Cocoa 6.5 (???) <e9318c93615b27231498bbe585b8da98> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x914dd000 - 0x914e1fff libGIF.dylib ??? (???) <713b902cb8f54365b1c78ff3507494a7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9159a000 - 0x91614ff8 com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91615000 - 0x91642feb libvDSP.dylib ??? (???) <e89461ed03200fb3c0304e62e14a42ed> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x916f3000 - 0x91b03fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91b53000 - 0x91b55fff com.apple.securityhi 3.0 (30817) <020419ad33b8638b174e1a472728a894> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x91d13000 - 0x923b3fe3 com.apple.CoreGraphics 1.409.3 (???) <25dceb14af3455b768f56e8765ecf3ca> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x923b4000 - 0x926bcfff com.apple.HIToolbox 1.5.5 (???) <b17766e3d8800a73f534c41f624f5ac4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x928af000 - 0x92d80fbe libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x92d81000 - 0x92d87fff com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92d88000 - 0x92da7ffa libJPEG.dylib ??? (???) <348a77547e3646c80704ddfd88f6e008> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x92e51000 - 0x92f1cfff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x92f1d000 - 0x92f1dffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92f69000 - 0x930d0ff3 libSystem.B.dylib ??? (???) <b47c8e6e45aef620730710a732bf1930> /usr/lib/libSystem.B.dylib
0x930d1000 - 0x9346efef com.apple.QuartzCore 1.5.8 (1.5.8) <a28fa54346a9f9d5b3bef076a1ee0fcf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9346f000 - 0x934a9fe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9360e000 - 0x93e0cfef com.apple.AppKit 6.5.7 (949.46) <a80f8cb62f6bdcb3bed3c8675d55881d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93e0d000 - 0x93e94ff7 libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
0x93e95000 - 0x93f3cfeb com.apple.QD 3.11.56 (???) <a94d0f5438b730e88e5efdb233295c52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94076000 - 0x940bffef com.apple.Metadata 10.5.2 (398.25) <bf7f665f6ad79df3a8355b41fa1ed207> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x940c0000 - 0x940d8fff com.apple.openscripting 1.2.8 (???) <54ab21172b8b3caa601dde44872a9c0d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x940d9000 - 0x940e9ffc com.apple.LangAnalysis 1.6.4 (1.6.4) <5c122260176a6bcd9da8c7f8bb567b34> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x941b4000 - 0x941c0ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x94430000 - 0x947eefea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x947ef000 - 0x947f4fff com.apple.CommonPanels 1.2.4 (85) <3b64ef0de184d09c6f99a1a7e77e42be> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x947f5000 - 0x94800fe7 libCSync.A.dylib ??? (???) <9e3544fe087bb4dc760b7afe0850dd6c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94821000 - 0x94837fff com.apple.DictionaryServices 1.0.0 (1.0.0) <7e9ff586b5c9d02b09e2a5527d98524f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9488a000 - 0x9488cff5 libRadiance.dylib ??? (???) <6d980a95dd5a8448e2846568cc1458cd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94a22000 - 0x94a22ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x94d4a000 - 0x94d81fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <cfd64ded4da1064ce316243fd425d5a4> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94d82000 - 0x94dfffef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x95def000 - 0x95e0dfff libresolv.9.dylib ??? (???) <36c871d5da9b49bb5bcf0449833d1dc5> /usr/lib/libresolv.9.dylib
0x95e0e000 - 0x95e0eff8 com.apple.ApplicationServices 34 (34) <e9cd7c823062c4382d89e3c9997f4739> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x95e0f000 - 0x95e0fffa com.apple.CoreServices 32 (32) <2760719f7a81e8c2bdfd15b0939abc29> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95e10000 - 0x95f56ff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <c0d51a3b27fe6977d8db45c84c7ff46b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95f5d000 - 0x9600dfff edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x960f0000 - 0x9636cfe7 com.apple.Foundation 6.5.8 (677.24) <aa84b0383891378c348ffa4a94853082> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9636d000 - 0x963c9ff7 com.apple.htmlrendering 68 (1.1.3) <a9f65fa1c4668dc7c49af5bf7d5287ad> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x963ca000 - 0x9651cff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9653b000 - 0x965c7ff7 com.apple.LaunchServices 290.3 (290.6) <bdba267184df88bd5b8e2116ea903872> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x965c8000 - 0x965ccfff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x96604000 - 0x9662ffe7 libauto.dylib ??? (???) <a64961ed20db64f0f439bfbc6f962bf9> /usr/lib/libauto.dylib
0x96630000 - 0x96769ff7 libicucore.A.dylib ??? (???) <cac059ebdac7d9a63ee0f7a648c9f6cf> /usr/lib/libicucore.A.dylib
0x9676a000 - 0x96824fe3 com.apple.CoreServices.OSServices 227 (227) <30cebcb68b1b571df7d77474e0c31556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x96842000 - 0x96842ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x968b7000 - 0x968d2ffb libPng.dylib ??? (???) <e92ab921713f1c28bc639d68683b8ee3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x968d3000 - 0x968e8ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x968e9000 - 0x9699bffb libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
0x9699c000 - 0x969a3ffe libbsm.dylib ??? (???) <5582985a86ea36504cca31788bccf963> /usr/lib/libbsm.dylib
0x969ef000 - 0x96ad0ff7 libxml2.2.dylib ??? (???) <2f6b294896866822330a8888b7f53b75> /usr/lib/libxml2.2.dylib
0x96ad1000 - 0x96b10fef libTIFF.dylib ??? (???) <1b5ab7f4bb5251ce1488dd0b1e21ad39> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96b61000 - 0x96b90fe3 com.apple.AE 402.3 (402.3) <b13bfda0ad9314922ee37c0d018d7de9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x96bd8000 - 0x96c7cfec com.apple.CFNetwork 438.10 (438.12) <fde64bbb20532794396fb21911ccaa98> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x96c7d000 - 0x96cd7ff7 com.apple.CoreText 2.0.4 (???) <f0b6c1d4f40bd21505097f0255abfead> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x96cd8000 - 0x96d01fff libcups.2.dylib ??? (???) <1b0435164b9dc6c773d0b1f24701e554> /usr/lib/libcups.2.dylib
0x96d02000 - 0x96d5bff7 libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x96d5c000 - 0x96e8ffef com.apple.CoreFoundation 6.5.6 (476.18) <2d52bab73660117571bd6486dc318f8e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x96e90000 - 0x96f78ff3 com.apple.CoreData 100.2 (186.1) <8fb61e1714a4b8d587ce97605ad32547> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x96f86000 - 0x96f8dfe9 libgcc_s.1.dylib ??? (???) <28a7cbc3a5ca2982d124668306f422d9> /usr/lib/libgcc_s.1.dylib
0x96fbd000 - 0x96fcbffd libz.1.dylib ??? (???) <545ca09467025f77131cfac09d8b9375> /usr/lib/libz.1.dylib
0x96fcc000 - 0x96fd3ff7 libCGATS.A.dylib ??? (???) <211348279493364e9920adc86484cedd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x96fd4000 - 0x9705efe3 com.apple.DesktopServices 1.4.8 (1.4.8) <3065de6531ce839c7cb5b6dd70e03f4f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9705f000 - 0x970bcffb libstdc++.6.dylib ??? (???) <6106b1f2b0b303b06ae476253dbb5f3f> /usr/lib/libstdc++.6.dylib
0x970bd000 - 0x970d5ff7 com.apple.CoreVideo 1.6.0 (20.0) <dd60118bac9aefaf88d9ab44558f05c4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97114000 - 0x972e5ffb com.apple.security 5.0.5 (36371) <c13e0bb1acfdcf94be4d3ee118ef190e> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97315000 - 0x97318fff com.apple.help 1.1 (36) <175489f8adf287b3ebd259362b0292c0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x97319000 - 0x97398ff5 com.apple.SearchKit 1.2.1 (1.2.1) <4ebff1a287bd6686107fa50d5a21b000> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x97441000 - 0x974cdff7 com.apple.framework.IOKit 1.5.2 (???) <97b9f9d584f48891377f0481b9104434> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
thanks,
Victor
