2 Replies Latest reply on Apr 22, 2010 10:56 AM by avdave
    Problem casting a string to image
    avdave
      Hello,
        I am currently having problem to cast a string to an image in my function. Here's the details
      1) I have declared few image holders as below:
                <mx:Image id="img0" x="40" y="80" width="250" height="550" mouseDown="img0_mouseDownHandler(event)"/>
      <mx:Image id="img1" x="298" y="80" width="240" height="270" mouseDown="img1_mouseDownHandler(event)"/>
      2) Through Http Service I am then getting the rss feed of xml in my result handler function.
          Also, in the same function I am building xmlList for my photo locations in the XML
              photoXMLList = tXML.entry.link.(@rel == 'enclosure').@href;
      3) After this I am looping through the index to traverse xm llist and place the photo into image place holders based on the current index of traversal:
      //declaration
      var strIndx:String; // string holds dynamically generated image id
      var index: int;
      var image:Image;
      //initialize index
      image = new Image();
      index=0;
      img= "img";
      //loop through index and ge
      for (n=index; n <=index+4;n++)
                strIndx = img +(index.toString());// make the strIndx to image id of current value e.g. first value would be img0 here
                if (tXML.entry[index].category.@term == "550")
                      if ( index == 0 )
                                    Alert.show(strIndx); // shows img0
                                // problem here...not able to cast the indx containing string value of image id i.e. img0
                                //    into image component,  more importantly image id
                                  image=mx.controls.Image(strIndx);
                                  image.source = photoXMLList[index];
      As explained in above code I am not able cast the string value of image id's (strIndex in above case) to actual Image value. I have tried to do that using casting to image variable but flex is not conevrting it for some reasons.
      I would  Highly appreciate prompt help on this!
      Akshay
        • 1. Re: Problem casting a string to image
          David_F57 Level 5
          hi
          Also tried to answer this in the other forum
          i'm having a little trouble trying to work out what you are trying to do, but if I have an'array' of images then
          for (var i:Number=0; i < data.length; i++)
               var img:Image= new Image();
               img.id = "img"+String(i);
               img.addEventListener(MouseEvent.CLICK,myImageClicked);
               img.source=data[i].imagename;
          now I have 10 images that have ids from img0 to img9, an event that is called if they are clicked each image is loaded from a collection called data which contains the name of the image.
          David.
          • 2. Re: Problem casting a string to image
            avdave Level 1
            Thanks David for your patient and helpful replies so far..
               Here's the full code.. Please let me know what you think
            Akshay
            ------------------------------------------------------ Code-----------------------------------------------------------------------------------
               xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="1250" creationComplete="photoService_T.send(),photoService_O.send()"  minHeight="600" backgroundColor="black">
            <fx:Style source="Flickr_Test.css"/>
            <fx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            import mx.controls.Alert;
            import mx.controls.Image;
            import mx.effects.Resize;
            import mx.events.FlexEvent;
            import mx.events.ItemClickEvent;
            import mx.events.ListEvent;
            import mx.events.MoveEvent;
            import mx.events.ResizeEvent;
            import mx.managers.PopUpManager;
            import mx.rpc.events.FaultEvent;
            import mx.rpc.events.ResultEvent;
            import mx.utils.object_proxy;
            [Bindable]
            public var photoXMLList:XMLList;
            private var img:Image;
            private var image:Image;
            public var photoXMLList_new:XMLList;
            //private var img_new:Image;
            var nsDefault:Namespace = new Namespace("http://www.w3.org/2005/Atom");
            private function photoResultHandler_T(re:ResultEvent):void {
                      default xml namespace = nsDefault;
                     var img:String;
                    var indx: String;
                     var booltest:Boolean;
                      img="img";
                      var tXML:XML = re.result as XML;
                var n:int;
                 for (n=0; n <=5;n++)
                            image.id = img +String(n);
                          Alert.show(image.id.toString());
                        if (tXML.entry[n].category.@term == "550")
                                   if ( n == 0 )
                                     image.source = photoXMLList[n];
            private function photoFaultHandler_T(fe:FaultEvent):void {
            Alert.show(fe.fault.message);
            protected function photoResultHandler_O(rew:ResultEvent):void
            // TODO Auto-generated method stub
            var tXML_new:XML = rew.result as XML;
            photoXMLList_new = tXML_new.entry.link.(@rel == 'enclosure').@href;
            protected function photoFaultHandler_O(fen:FaultEvent):void
            Alert.show(fen.fault.message);
            </fx:Script>
            <fx:Declarations>
            <s:HTTPService id="photoService_T" url="http://api.flickr.com/services/feeds/photoset.gne?set=72157623742603753&nsid=48951865@N07" resultFormat="e4x" result="photoResultHandler_T(event);" fault="photoFaultHandler_T(event);"/>
            <s:HTTPService id="photoService_O" url="http://api.flickr.com/services/feeds/photoset.gne?set=72157623867029406&nsid=48951865@N07" resultFormat="e4x" result="photoResultHandler_O(event);" fault="photoFaultHandler_O(event);"/>
            <mx:WipeDown id="image_addedEffect" startDelay="50"></mx:WipeDown>
            <mx:Parallel id="image_removedEffect">
            <mx:Zoom />
            <mx:Fade />
            </mx:Parallel>
            </fx:Declarations>
            <mx:Image id="img0" x="40" y="80" width="250" height="550" />
            <mx:Image id="img1" x="974" y="80" width="250" height="550" mouseDown="img6_mouseDownHandler(event)"/>
            </s:Application>
            Message was edited by: avdave
