2 Replies Latest reply on Apr 22, 2010 4:02 PM by CrazyMerlin
    Can someone explain this error?
    CrazyMerlin Level 1
      I needed to maintain scope while calling a method on an inherited class that is used as a callback from a HTTPService request. I thought I would try the known JS method of assigning a variable to this and then using that variable as the reference in the callback.
      That is when I noticed this issue: I had been reading about how AS creates a Class object for each class defined in an application, however if I do this:
      protected var self:Class = this;
      or
      protected var self:Class;
      public function className():void {
        this.self = this;
      I get an implicit coersion error: 1067: Implicit coercion of a value of type com.webtop:AdminClass to an unrelated type Class.
      This makes no sense at all. If a Class object is created for my class, then my class is a Class. This can be proved by:
      private var activeClass:Class = null;
      private function someFunction():void {
        this.activeClass = CategoryClass;
      where CategoryClass is an uninstantiated class.
      So if this references my class, what exactly is this?
