4 Replies Latest reply on Apr 22, 2010 2:09 PM by RandomReado
    Calling methods from custom class?
    RandomReado Level 1
      Here's what I have:
      src\MainApp.mxml
      src\components\engine\Posts.as
      In Posts.as there's a public function "addPost()".
      In the MainApp.mxml I've specified:
      import components.engine.Posts;
      However when I try to use "addPost()" as a click handler for a button, Flex says:
      "1180: Call to a possibly undefined method addPost"
      Can anyone tell me why? Thanks in advance.
        • 1. Re: Calling methods from custom class?
          levancho Level 3
          you need either instance of Posts or make the function addPost as static
          both way you have to qualify method with intsance name or clas name
          var myinstance:Posts = new Posts();
          myinstance.addPost()
          or if its static
          Posts.addPosts();
          • 2. Re: Calling methods from custom class?
            RandomReado Level 1
            I see what you mean. I just changed addPost() to:
            public static function addPost(id:Number):void
            Then in the click handler:
            Posts.addPost(1)
            This seemed to work. However inside the addPost method is a call to the HTTPService, and I have a result and fault handler, both are pointing to private methods inside the Posts.as file. When I applied the static to the addPost() method, Flex said it could no longer see the handler methods, both of which were private. When I made them static the error went away.
            Do you know why this is?
            • 3. Re: Calling methods from custom class?
              levancho Level 3
              In that case you need instance of posts not statix function
              -- Sent from my Palm Pre
              Posts.addPost(1)
              This seemed to work. However inside the addPost method is a call to the HTTPService, and I have a result and fault handler, both are pointing to private methods insode the Posts.as file. When I applied the static to the addPost() method, Flex said it could no longer see the handler methods, both of which were private. When I made them static the error went away.
              • 4. Re: Calling methods from custom class?
                RandomReado Level 1
                Ah Ok. Thanks.
