3 Replies Latest reply on Apr 26, 2010 9:27 PM by GordonSmith
    Date Calculation Problem
    jfillman Level 1
      The code below correctly calculates the date the every other time the button is clicked.  I would expect to get the same date for both the currentDate and tempDate values, every time I click the button.
      Code:
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx"
      width="
      100%" height="100%" creationComplete="init();">
      <fx:Script>
      <![CDATA[
      private var currentDate:Date = new Date();
      private var tempDate:Date = new Date();
      private var newDate:Date;
      public function calculateDate():void {
      newDate =
      new Date();
      currentDate.fullYear = newDate.fullYear;
      currentDate.month = newDate.month;
      currentDate.date = newDate.date;
      currentDate.hours = 0;
      currentDate.minutes = 0;
      currentDate.seconds = 0;
      currentDate.milliseconds = 0;
      trace ("Current Date: "+currentDate);
      tempDate.fullYear = newDate.fullYear;
      tempDate.month = newDate.month;
      tempDate.date = 0;
      tempDate.hours = 0;
      tempDate.minutes = 0;
      tempDate.seconds = 0;
      tempDate.milliseconds = 0;
      trace ("Temp Date: "+tempDate);
      </fx:Script>
      <s:Button click="calculateDate()" label="Click Here" />
      </s:Application>
      Trace Output:
           First Click:
                    Current Date: Thu Apr 22 00:00:00 GMT-0700 2010
                     Temp Date: Wed Mar 31 00:00:00 GMT-0700 2010
           Second Click:
                     Temp Date: Fri Apr 30 00:00:00 GMT-0700 2010
           Third Click:
           Fourth Click:
        • 1. Re: Date Calculation Problem
          David_F57 Level 5
          hi,
          this code works.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
          <![CDATA[
          private var currentDate:Date;
          private var tempDate:Date;
          public function calculateDate(myDate:Date):void {
          currentDate = new Date();
          tempDate = new Date();
          currentDate.fullYear = myDate.fullYear;
          currentDate.month = myDate.month;
          currentDate.date = myDate.date;
          tempDate.fullYear = myDate.fullYear;
          tempDate.month = myDate.month;
          tempDate.date = 0;
          tempDate.hours = 0;
          </fx:Script>
          <s:Button click="calculateDate(new Date())" label="Click Here" />
          </s:Application>
          • 2. Re: Date Calculation Problem
            jfillman Level 1
            The issue occurs when I set tempDate.date = 0
            If I set it to 1, and then account for it in calculating the .date vaule, this works correctly.
            tempDate.date = 0 alternates between the last day of the previous month and the last day of the current month, for whatever reason. It's odd, maybe a bug, but I can work around it.
            • 3. Re: Date Calculation Problem
              GordonSmith Level 4
              The 1st day of any month is date=1, not date=0. I'm not sure whether the behavior for out-of-range values for date, such as 0, is well-defined by the Ecmascript spec. If it is, you should file a bug.
              Gordon Smith
              Adobe Flex SDK Team
