3 Replies Latest reply on Apr 23, 2010 7:52 PM by mitpig
    may i cancel dataGroup rollOverColor property??
    mitpig
      hi there:
      recently, i'm trying to replace repeater by custom ItemRenderer , and use the dataGroup to contain them.
      but i met some problem ,  it will change background color when rollOver and rollOut
      can i disable the function?  i just wanna use dataGroup , i don't wanna to change background color .........~_~
      could anyone help me? thx~
        • 1. Re: may i cancel dataGroup rollOverColor property??
          David_F57 Level 5
          hi,
          if the rollover color matches the background color then you have the effect you need otherwise you have to customise the 'states' of the datagroup or item renderer
          <s:DataGroup id="dg" rollOverColor="{dg.getStyle('contentBackgroundColor')}">
          David.
          • 2. Re: may i cancel dataGroup rollOverColor property??
            Shongrunden Adobe Employee
            You can turn off the highlight in the renderer by setting autoDrawBackground="false", for example:
                           xmlns:s="library://ns.adobe.com/flex/spark">
                <s:DataGroup>
                    <s:itemRenderer>
                        <fx:Component>
                            <s:ItemRenderer autoDrawBackground="false">
                                <s:Label text="{data}" />
                            </s:ItemRenderer>
                        </fx:Component>
                    </s:itemRenderer>
                    <s:layout>
                        <s:VerticalLayout />
                    </s:layout>
                    <s:dataProvider>
                        <s:ArrayList>
                            <fx:String>a</fx:String>
                            <fx:String>b</fx:String>
                            <fx:String>c</fx:String>
                        </s:ArrayList>
                    </s:dataProvider>
                </s:DataGroup>
            </s:Application>
            • 3. Re: may i cancel dataGroup rollOverColor property??
              mitpig Level 1
              thx it really helps me!
              thank you all ^.^
