2 Replies Latest reply on Apr 23, 2010 12:40 AM by pgpradeep
    Is it possible to create an array of labels programmatically?
    pgpradeep
      Is it possible to have an array of labels, or programmatically create label names (ie label01, label02 etc.)?
        • 1. Re: Is it possible to create an array of labels programmatically?
          David_F57 Level 5
          hi,
          this should do the trick
          David.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
             creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.FlexEvent;
          import spark.components.Label;
          private var labelCollection:ArrayCollection = new ArrayCollection(["First", "Second", "Third", "Last"]);
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          for (var i:Number =0; i < labelCollection.length; i++)
          var lbl:Label = new Label();
          lbl.id = "lbl_"+String(i);
          lbl.text = labelCollection[i];
          lbl.width = 100;
          labelbar.addElement(lbl);
          </fx:Script>
          <s:HGroup id="labelbar"/>
          </s:Application>
          • 2. Re: Is it possible to create an array of labels programmatically?
            pgpradeep Level 1
            In my app, Im using viewStacks and canvases to render different views for
            the same mxml.
            I want to change the text dynamically(at a later stage, from a different canvas) once the labels are created.
            How do I get a handle to the labels then?
            "lbl_"+String(i) as Label isnt working.
            Pradeep.
