This content has been marked as final.
Show 7 replies
1. Re: spry menu displays behind video content
Newsgroup_User Sep 18, 2007 1:30 PM (in response to RGracia)All Active content on a page will always rise to the top, so to speak,
including Flash, certain form elements, Java applets, and Active X controls.
This means that each of these will poke through layers. There is not a good
cross-browser/platform reliable way to solve this issue, but if you can be
confident in your visitors using IE 5+ or NN6+, then you can use the Flash
wmode parameter (however, Safari does not support this properly!).
Adobe articles:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_15523
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=tn_14201
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.dreamweavermx-templates.com - Template Triage!
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
"RGracia" <webforumsuser@macromedia.com> wrote in message
news:fcp4e1$50u$1@forums.macromedia.com...
> Hi Guys, I have built a spry horizontal menu right above a section which
> contains a video as the first item. The menu is right above this area and
> when
> I test on Firefox and Safari, the menu drops down behind the video. IE 7
> works
> correctly diplaying the menu over the video object. I have seen other
> posts
> with opposite problems where IE does not show the menu over the rest of
> the
> content. Any suggestions with the video issue?
2. Re: spry menu displays behind video content
deesadler Sep 18, 2007 2:57 PM (in response to RGracia)If it's Flash, add a new parameter to your video code.
<param name="wmode" value="transparent">
Flash is always at a 0 Z index and always above everything else, unless you set the window mode to transparent. Works with a flash file under CSS drop down menus too. Hope that helped in some way.
Dee -
3. Re: spry menu displays behind video content
deesadler Sep 18, 2007 2:58 PM (in response to RGracia)sorry Murray (Adobe Community Expert, not ACE) ;) I didn't see all of your answer.
Dee -
4. Re: spry menu displays behind video content
Newsgroup_User Sep 18, 2007 3:32 PM (in response to RGracia)That's OK. And by the way, there's no z-index involved in this. It's that
Flash is constantly being redrawn on the page, hence Active content.
"deesadler" <webforumsuser@macromedia.com> wrote in message
news:fcphma$k4q$1@forums.macromedia.com...
> answer.
> Dee
5. Re: spry menu displays behind video content
RGracia Sep 18, 2007 3:40 PM (in response to RGracia)Cool I will try this tomorrow and report back after testing, thanks guys. -
6. Re: spry menu displays behind video content
Newsgroup_User Sep 19, 2007 3:48 AM (in response to RGracia)Good luck!
news:fcpk47$mlg$1@forums.macromedia.com...
7. Re: spry menu displays behind video content
RGracia Sep 19, 2007 6:01 AM (in response to RGracia)well unfortunately the <param name="wmode" value="transparent"> trick had no effect on the page. I guess I will have to move that flash video box elsewhere on the layout, what a pain!
