16 Replies Latest reply on May 7, 2010 6:14 AM by phantoxe
    AdvancedDataGrid Print Issue
    Rajeesh Upendran
      Hi
      I am using the AdvanceDataGrid to display the record. When try to use the FlexPrintJob object to print the AdvanceDataGrid, It is just the printing the first page and rest of page are getting ignored. Also some time the below error is showing
      Error:Error #1502: A script has executed for longer than the default timeout period of 15 seconds.
      at flash.printing::PrintJob/get pageWidth()
      at mx.printing::FlexPrintJob/start()
      at index/btnPrint_click_handler()
      Code is given below
      public function btnPrint_click_handler ( e:MouseEvent ) : void
              // Create an instance of the FlexPrintJob class.
              var printJob:FlexPrintJob = new FlexPrintJob();
              // Initialize the PrintAdvancedDataGrid control.
              var printADG:PrintAdvancedDataGrid =
                  new PrintAdvancedDataGrid();
              // Exclude the PrintAdvancedDataGrid control from layout.
              printADG.includeInLayout = false;
              adg1.validateNow();
              adg1.expandAll();
              printADG.source = adg1;
              // Add the print-specific control to the application.
              addChild(printADG);
              // Start the print job.
              if (printJob.start() == false) {
                  // User cancelled print job.
                  // Remove the print-specific control to free memory.
                  removeChild(printADG);
                  return;
              // Add the object to print. Do not scale it.
              printJob.addObject(printADG, FlexPrintJobScaleType.NONE);
              // Send the job to the printer.
              printJob.send();
      Can you please guide me
      regards,
      Rajeesh
        • 1. Re: AdvancedDataGrid Print Issue
          Sameer Bhatt Adobe Employee
          You have to call nextPage() and add each page to printing -
                          while (printADG.validNextPage)
                              printADG.nextPage();
          • 2. Re: AdvancedDataGrid Print Issue
            Ansury Level 3
            http://www.adobe.com/devnet/flex/tourdeflex/langref/mx/printing/PrintAdvancedDataGrid.html #includeExamplesSummary
            Edit: That's curious, the link above doesn't call nextPage() like I believe the PrintDataGrid example does.  No time to look at that now but hopefully this still works/helps.  Maybe you need to look at this too for a fancier example:
            http://www.adobe.com/livedocs/flex/3/langref/mx/printing/PrintDataGrid.html#includeExample sSummary
            Printing in Flex can be a challenge and I'm very disappointed that Flex 4 (not to mention Flash 10) didn't improve on this capability.
            • 3. Re: AdvancedDataGrid Print Issue
              Rajeesh Upendran Level 1
              Hi Sameer Bhatt,
              Thanks for your support.
              I have tried this code but printADG.validNextPage value always false. In AdvancedDataGrid data is showing but I could not able to print the all values.
              Rajeesh
              • 4. Re: AdvancedDataGrid Print Issue
                Hi Ansury
                I have used the same code but no luck
                Rajeesh
                • 5. Re: AdvancedDataGrid Print Issue
                  Can you post a sample?
                  • 6. Re: AdvancedDataGrid Print Issue
                    Hi Sameer,
                    Code is given below
                            adg1.validateNow();
                            adg1.expandAll();
                            printADG.validateNow();
                            //Alert.show(printADG.validNextPage);
                    Rajeesh
                    • 7. Re: AdvancedDataGrid Print Issue
                      You have to add the PrintAdvancedDataGrid control (as a child) to the Application and then later remove it.
                      • 8. Re: AdvancedDataGrid Print Issue
                        I have tried this but no luck . I getting this error
                        Error: Error #1502: A script has executed for longer than the default timeout period of 15 seconds.
                            at mx.printing::FlexPrintJob/addObject()[C:\autobuild\3.2.0\frameworks\projects\framework\sr c\mx\printing\FlexPrintJob.as:358]
                            at index/btnPrint_click_handler()[X:\wwwroot\IBMFLEX3\SalesCancelReport\src\com\controller.a s:334]
                        Code is given below
                                adg1.validateNow();
                                adg1.expandAll();
                                addChild(printADG);
                                    return;
                                printJob.send();
                        • 9. Re: AdvancedDataGrid Print Issue
                          Call addChild(printADG); just after creating the printADG, that is, do -
                          addChild(printADG);
                          .... rest of the code .....
                          • 10. Re: AdvancedDataGrid Print Issue
                            I tried the below code but no progress
                            addChild(printADG);
                            adg1.validateNow();
                            adg1.expandAll();
                            return;
                            printJob.send();
                            Rajeesh
                            • 11. Re: AdvancedDataGrid Print Issue
                              Here is a working sample -
                                                xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                                   <s:layout>
                                        <s:VerticalLayout/>
                                   </s:layout>
                                   <fx:Script>
                                        <![CDATA[
                                             import mx.printing.FlexPrintJob;
                                             import mx.printing.FlexPrintJobScaleType;
                                             import mx.printing.PrintAdvancedDataGrid;
                                             protected function button1_clickHandler(event:MouseEvent):void
                                                  padg.visible = true;
                                                  padg.includeInLayout = true;
                                                  adg.expandAll();
                                                  adg.validateNow();
                                                  padg.source = adg;
                                                  padg.validateNow();
                                                  if (printJob.start())
                                                       printJob.addObject(padg, FlexPrintJobScaleType.NONE);
                                                       while(padg.validNextPage)
                                                            padg.nextPage();
                                                       printJob.send();
                                                  padg.visible = false;
                                                  padg.includeInLayout = false;
                                   </fx:Script>
                                   <fx:Declarations>
                                        <!-- Place non-visual elements (e.g., services, value objects) here -->
                                        <fx:Array id="arr">
                                             <fx:Object name="A" sno="1" age="10" />
                                             <fx:Object name="A1" sno="2" age="20" />
                                             <fx:Object name="A2" sno="3" age="30" />
                                             <fx:Object name="A3" sno="4" age="40" />
                                             <fx:Object name="A4" sno="5" age="50" />
                                             <fx:Object name="A5" sno="6" age="60" />
                                             <fx:Object name="A6" sno="7" age="70" />
                                             <fx:Object name="A7" sno="8" age="60" />
                                             <fx:Object name="A8" sno="9" age="50" />
                                             <fx:Object name="A9" sno="10" age="40" />
                                             <fx:Object name="A10" sno="11" age="30" />
                                             <fx:Object name="A11" sno="12" age="20" />
                                             <fx:Object name="A12" sno="13" age="10" />
                                             <fx:Object name="A13" sno="14" age="30" />
                                             <fx:Object name="A14" sno="15" age="40" />
                                             <fx:Object name="A15" sno="16" age="30" />
                                             <fx:Object name="A16" sno="17" age="20" />
                                             <fx:Object name="A17" sno="18" age="10" />
                                             <fx:Object name="A18" sno="19" age="30" />
                                             <fx:Object name="A19" sno="20" age="40" />
                                        </fx:Array>
                                   </fx:Declarations>
                                   <mx:PrintAdvancedDataGrid id="padg" includeInLayout="false" visible="false" width="400" height="400" />
                                   <mx:AdvancedDataGrid id="adg" creationComplete="gc.refresh();">
                                        <mx:dataProvider>
                                             <mx:GroupingCollection2 id="gc" source="{arr}">
                                                  <mx:Grouping label="name">
                                                       <mx:GroupingField name="name" />
                                                  </mx:Grouping>
                                             </mx:GroupingCollection2>
                                        </mx:dataProvider>
                                        <mx:columns>
                                             <mx:AdvancedDataGridColumn dataField="name" />
                                             <mx:AdvancedDataGridColumn dataField="sno" />
                                             <mx:AdvancedDataGridColumn dataField="age" />
                                        </mx:columns>
                                   </mx:AdvancedDataGrid>
                                   <s:Button label="Print" click="button1_clickHandler(event)" />
                              </s:Application>
                              • 12. Re: AdvancedDataGrid Print Issue
                                phantoxe
                                Is this a Flash Builder 4 example?
                                • 13. Re: AdvancedDataGrid Print Issue
                                  Yes this sample is built with Flex 4 SDK. You can use the same printing code in Flex 3 SDK also.
                                  • 14. Re: AdvancedDataGrid Print Issue
                                    phantoxe Level 1
                                    Hi Guys... somebody help me? I need put a company logo before my PRINT. And I need put other Logo in the END my Page... I TRIED this but dosent work:
                                    var companyLogo:Image = new Image():
                                    companyLogo.source = "assets/logo.png";
                                    var miniCompanyLogo:Image = new Image():
                                    miniCompanyLogo.source = "assets/logo_mino.png";
                                    printJob.addObject(companyLogo, FlexPrintJobScaleType.NONE); // This is my First Logo
                                    printJob.addObject(padg, FlexPrintJobScaleType.NONE); // This is my PrintAdvancedDatagrid
                                    printJob.addObject(miniCompanyLogo, FlexPrintJobScaleType.NONE); // This is my Last Logo
                                    Eduardo
                                    • 15. Re: AdvancedDataGrid Print Issue
                                      You are not adding the Images (as a child) to the  Application.
                                      • 16. Re: AdvancedDataGrid Print Issue
                                        phantoxe Level 1
                                        Hi Sameer... thanks pro reply...
                                        I tried this man e dosen't work:
                                                            var logoPrint:Image = new Image();
                                                            logoPrint.source = "assets/iobras.png";
                                                            addChild(logoPrint);
                                                            listRelDespesas_dg.expandAll();
                                                            listRelDespesas_dg.validateNow();
                                                            padg.source = listRelDespesas_dg;
                                                            padg.validateNow();
        printJob.addObject(logoPrint, FlexPrintJobScaleType.NONE);
        padg.nextPage();
        printJob.send();
