3 Replies Latest reply on Sep 5, 2010 10:31 PM by Shongrunden
    tabbar spark, states
    matthieuj
      In a component that has multiple states, I use a spark TabBar based on a ViewStack
      containing a list of Navigator Content.
      The number of tabs changes when the component states
      changes.
      The TabBar works, but sometimes there are some bugs: after a state change, it can
      have multiple tabs selected.
      Bug1:
      Select in state three (using the comboBox)
      then I select the last tab
      then I select the state two (using the comboBox).
      Result: the onglet3 and 4 are selected.
      Bug2:
        I want to force the selection of the first tab after a change
      state (idViewStack.selectedIndex = 0;)
      Result: multiple tabs are selected.
      code:
      <s:VGroup xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:ns="library://ns.adobe.com/flex/mx"
                    xmlns:tabbarNavigation="tabbarNavigation.*"
                    xmlns:views="views.*"
                    width="1000" height="800"
                    creationComplete="application1_creationCompleteHandler(event)" xmlns:tabbarNavigation2="tabbarNavigation2.*" xmlns:tabBarNavigation="tabBarNavigation.*">
            <fx:Script>
                  <![CDATA[
                        import mx.collections.ArrayCollection;
                        import mx.controls.Alert;
                        import mx.events.FlexEvent;
                        import spark.events.IndexChangeEvent;
                        [Bindable()]
                        public var dataproviderStatesChoise:ArrayCollection = new ArrayCollection();
                        protected function application1_creationCompleteHandler(event:FlexEvent):void
                              dataproviderStatesChoise.addItem("state1");
                              dataproviderStatesChoise.addItem("state2");
                              dataproviderStatesChoise.addItem("state3");
                              statesChoise.selectedIndex=0;
                        protected function changeHandler(event:IndexChangeEvent):void
                              if(event.newIndex==0){
                                   currentState="state1";
                              }else if(event.newIndex==1){
                                   currentState="state2";
                              }else {
                                   currentState="state3";
            </fx:Script>
            <s:states>
                  <s:State name="state1"/>
                  <s:State name="state2"/>
                  <s:State name="state3"/>
            </s:states>
            <s:ComboBox id="statesChoise" dataProvider="{dataproviderStatesChoise}" change="changeHandler(event)"/>
            <s:TabBar dataProvider="{idViewStack}" id="idTabBar"  />
            <ns:ViewStack id="idViewStack" width="95%" height="85%" left="8" y="23" >
                  <s:NavigatorContent label="Tab1"  width="100%" height="100%" includeIn="state3">
                        <s:Label text="Tab1" />
                  </s:NavigatorContent>
                  <s:NavigatorContent label="Tab2"  width="100%" height="100%" includeIn="state2,state3">
                        <s:Label text="Tab2" />
                  <s:NavigatorContent label="Tab3"  width="100%" height="100%" >
                        <s:Label text="Tab3" />
                  <s:NavigatorContent label="tab4 "  width="100%" height="100%">
                        <s:Label text="Tab4" />
            </ns:ViewStack>
      </s:VGroup>
        • 1. Re: tabbar spark, states
          Shongrunden Adobe Employee
          It looks like bug1 and bug2 is the same issue.  Here is a reduced test case that demonstrates the bug:
                    xmlns:mx="library://ns.adobe.com/flex/mx">
              <s:states>
              </s:states>
              <s:controlBarContent>
                  <s:Button label="1. go to state2" click="currentState='state2'" />
                  <s:Button label="2. go to state3" click="currentState='state3'" />
              </s:controlBarContent>
              <s:TabBar dataProvider="{vs}" />
              <mx:ViewStack id="vs" y="25">
                  <s:NavigatorContent label="Tab1" includeIn="state3">
                  <s:NavigatorContent label="Tab2" includeIn="state2,state3">
                  <s:NavigatorContent label="Tab3">
              </mx:ViewStack>
          </s:Application>
          Steps to reproduce:
          1. Compile and run above MXML
          2. Click "1. go to state2"
          3. Click "2. go to state3"
          4. Notice two tabs show as selected
          Can you please file a bug at http://bugs.adobe.com/flex and post the link here?  Let me know if you would rather that I file it.
          • 2. Re: tabbar spark, states
            Raklar
            Did anything ever come of this as I'm still notcing this problem in flex now.
            • 3. Re: tabbar spark, states
              I couldn't find this issue in the bug base so I assume matthieuj didn't file it.  I filed it here: http://bugs.adobe.com/jira/browse/SDK-27755
