4 Replies Latest reply on Apr 23, 2010 11:03 AM by aoleson
    Spry Menu Bar
    aoleson
      I'm working with a Spry Menu Bar Vertical. My question is when I adjut the height of the menu bar, home come the text does not center in the menu bar? It stays on the top of the menu bar. How do I get it to center with in the box?
        • 1. Re: Spry Menu Bar
          Zabeth69 Level 5
          Apply line-height: [match height]; to your "a" or to your "li", either one will work. Applying line-height will give that height to every text-line in your menu. If you have menu items that run to two lines within the block, you will need to play around with the line-height, and perhaps make a secondary class with a /half/ line-height for those two-liners.
          Height merely applies a height, usually to a container or an image, whereas the text-attribute line-height is what you want. Line-height, in my mind, mimics the real-world type-body in foundry type...the piece of lead that the letter-part 'sits' on. So there is lead matrix above and below, virtually centering the letters on the piece of type.
          Beth
          • 2. Re: Spry Menu Bar
            aoleson Level 1
            Okay, I figured out the center on the text in the menu bar. Now for my next question how do I make the text bigger in the menu bar?
            • 3. Re: Spry Menu Bar
              Zabeth69 Level 5
              Your best bet, when you use a Spry Menu Bar, is to carefully learn to understand the Menu Bar's CSS stylesheet.
              Starting at the top of the Stylesheet, anywhere you find font-size: 100%; (or some other sizing), you can change it. I suggest changing one thing at a time, checking to see what changes on your stylesheet, until you find the combination that you want.
              Understanding menu bar stylesheets is a great lesson in understanding the CSS cascade and descendant styles.
              Change gingerly, check often, and keep your structural styles separate from your presentation styles...it is better to have an attribute:value pair once in a sheet where it will do good and work than to repeat it everywhere; you will have a hard time knowing which instance of the attribute:value pair is the one doing the heavy lifting if it is everywhere.
              Beth
              • 4. Re: Spry Menu Bar
                aoleson Level 1
                Thanks for all the help. I figured everthing out.
