0 Replies Latest reply on Apr 23, 2010 8:26 AM by sd55
    Control multiple accordions with a single control?
    sd55
      I want to control a the selectedIndex of a number of different accordions from a single control (e.g. a VSlider).
      Using the example at http://blog.flexexamples.com/2007/09/17/programmatically-changing-a-flex-accordion-contain ers-selected-index/, I've got a single VSlider controlling a single accordion ("mainhaccordiona"), using the code below. I'd like to control four accordions (mainhaccordiona, mainhaccordionb, mainhaccordionc, and mainhaccordiond) from the single VSlider.
      My ultimate goal is to set up both a "reset" function (open all panels at selectedIndex = 0) and also a randomizer (each selectedIndex is set to a random value within each accordion's range).
      Does anyone have any tips or is there an example already out there on the web that I've missed?
      Thanks!
      Scott
      private function init():void
      slider.maximum = mainhaccordiona.numChildren -1;
      slider.labels = [0, slider.maximum];
      private function dataTipFunc(item:Object):String
      return "selectedIndex = " + item.toString();
                <mx:ApplicationControlBar dock="true" fontSize="8">
      <mx:VSlider id="slider"
                      minimum="0"
                      liveDragging="true"
                      snapInterval="1"
                      tickInterval="1"
                      change="mainhaccordiona.selectedIndex = event.value;"
                      dataTipFormatFunction="dataTipFunc"
                      dataTipPlacement="bottom" />
      </mx:ApplicationControlBar>
