2 Replies Latest reply on Apr 18, 2011 12:45 PM by Anadi KUMAR
    FB3 Maven plug-in eclipse (error JRE)
    sun.kati
      Hi
      Need some help with error :
      Eclipse is running in a JRE, but a JDK  is required
         Some Maven plugins may not work when importing  projects or updating  source folders.
      Trying to  install Maven plug-in in order to use it in flexmojo.
      Was   fallowing Maven instalation from  http://www.maximporges.com/2009/09/22/how-to-install-m2eclipse-in-flex-builder-3  /  with few changes in order to make them work:
      Changes  in  maximprogress steps
      - step4 - has change url  from  http://m2eclipse.sonatype.org/update/ to  http://m2eclipse.sonatype.org/sites/m2e - as his link return error
      -  step4 - only selected  “Europa Discovery Site” as “The Eclipse Project  Updates” return error
      All  instalation went smooth  but...
      When in flex 3 clicked : File -> New   ->  Other.... -> Maven -> Maven Project... eclipse return  'warning':
      Was googling to find solution   and as far as know, issue is that eclipse run on JRE , so need to  change  it to JDK.
      People advice  to add command in  eclipse.ini file:
      -vm   "C:\Java\jdk1.6.0_13\bin\javaw.exe"
      ...In my Flex  Bulder 3 root  directory there is not any eclipse.ini file but is  FlexBuilder.ini .  Think is the same? I added this line but still the  same error...
      Any advice  what is wrong?
