0 Replies Latest reply on Apr 23, 2010 10:13 AM by Paul Reilly
    [svn:fx-trunk] 15669: * Package and class level javadoc for the flex2. compiler.css,
    Paul Reilly Level 1
      Revision: 15669
      Revision: 15669
      Author:   preilly@adobe.com
      Date:     2010-04-23 10:12:53 -0700 (Fri, 23 Apr 2010)
      Log Message:
      • Package and class level javadoc for the flex2.compiler.css,
        flex2.compiler.common, and flex2.compiler.config packages.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post-commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/ConfigurationPathResolver. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/FontsConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/FramesConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/LocalFilePathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MetadataConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/NamespacesConfiguration.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/PathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/SinglePathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/AdvancedConfigurationInfo. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/CommandLineConfigurator.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationFilter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationValue.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/FileConfigurator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/SystemPropertyConfigurator .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/ConditionTypeNotSupported.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/package.html
