2 Replies Latest reply on Apr 23, 2010 5:32 PM by Rothrock
    sound synch: stream vs event
    Grmfl
      I'm working in Flash CS3. My animation is about a minute long, with a single audio track that plays from beginning to end. The sound quality is noticably better when I set the synching to Event, but unless I set it to Stream the sound falls behind the animation. Is there any way to maintain proper synchronization with the Event setting?
      Also: will the lag be consistent on different machines and players? I thought about adjusting the timing of the animation so that it matches the Event-set sound in playback, but that's such a clunky a solution it seems likely to cause other problems.
      Thanks!
