5 Replies Latest reply on Apr 24, 2010 12:15 AM by AttaBoy2
    Importing externally stored as3 class code from XML?
    celebritymusic Level 1
      Hi
      I have the following code string stored in an XML file:
      MovieClip(parent).gotoAndStop(15);
      I've imported this to the global var...
      globals.data.navtest
      ...using...
      globals.data.navtest = test.toString();
      It works fine - if I trace(globals.data.navtest); it outputs MovieClip(parent).gotoAndStop(15);
      What I want to do now is actually use globals.data.navtest in my Flash project to execute MovieClip(parent).gotoAndStop(15);
      How do I do that?  Do I have to import it as something other than a string, or do I have to code something that tells flash "execute the code that is in globals.data.navtest" ?
      I want to keep all of the code in the XML tag, so I can change any of it without opening Flash CS4.
      Thanks for your help guys.
      Shaun
