6 Replies Latest reply on Apr 28, 2010 6:38 PM by vfouquereau
    Exporting to H264 using AAC input : sound skips
    vfouquereau
      Hi there,
      Let me try to get you guys all the information in one big chunk. http://forums.adobe.com/images/emoticons/happy.gif
      My computer :
      Intel Core i7 860
      8gb DDR3 RAM
      Western Digital WD5000AAKS HDD
      ATI Radeon HD4870
      ASUS P7P55D motherboard
      Windows 7 Home Premium (x64)
      Premiere Elements 8.0.1
      Everything is up to date to the latest version/driver
      The source material :
      Video :
      Video.m2ts
      1920x1080 AVCHD (Panasonic HDC-HS250, REC MODE: HA1920 [Highest quality])
      177 mb
      Audio :
      Case 1 :
      MP3FILE.MP3
      Stereo
      Case 2 :
      AACFILE.M4A
      Stereo
      Export settings (advanced) :
      Format: Quicktime
      Export Video : Yes
      Export Audio : Yes
      Video tab :
      Video Codec Section
      Video Codec: H.264
      Basic Settings Section
      Quality: 80
      Width : 1280
      Height : 720
      Frame Rate: 30
      Field Type: Progressive
      Aspect: Square Pixels
      Render at Maximum Depth : No
      Codec Settings: 24 bit
      Advanced Settings Section
      Set Key Frame Distance : Yes
      Key Frame Distance (framerate):: 24
      Optimize Stills: No
      Frame Reordering: No
      Bitrate Settings Section
      Set Bitrate : Yes
      Bitrate (kbps):: Yes, 4500
      Audio Tab :
      Audio Codec Section
      Audio Codec: AAC
      Basic Audio Settings
      Sample Rate: 48000 Hz
      Channels : Stereo
      The problem :
      It's quite simple, let’s expose with a couple of cases.
      Case 1: I use the MP3 file as the soundtrack (in the soundtrack “lane”), I export the clip. Everything is super, including audio.
      Case 2: I use the AAC file as the soundtrack. I export the clip. The audio skips beats at irregular times.
      Case 3 : I use both the MP3 and AAC file as the soundtrack. I export the clip. The audio skips beats at irregular times.
      As soon as I put an AAC file in there, the audio skipping begins. The video is fine, high quality all the way.
      What I checked :
      - The AAC file sounds perfect in every other audio program prior to encoding. The sound file is not the cause. I tried using multiple AAC and MP3 files, the problem is constant.
      - I am aware of the limits of the hardware and I know for SURE I’m not hitting them. This is not hardware related.
      - Every driver and every software is up to date.
      What’s left :
      Apart from transcoding my AAC files to MP3 every time I want to use them in movies, any idea?
