6 Replies Latest reply on Sep 19, 2007 6:55 AM by Ortho
    Find text between tags with regular expression
    Ortho
      I am trying to find specif text -- table names - within a <cfquery> tag in all my cfm files. I am using an extend find function in Homesite (I think Dreamweaver has the same functionality). This expression works:
      <[Cc][fF][qQ][uU][eE][rR][Yy] [^>]*>[^>]*(EventName|AttendeeName)[^>]*</[Cc][fF][qQ][uU][eE][rR][Yy]>
      for find the text EventName or AttendeeName. However, if there are other cf tags like <cfif> within the <cfquery>, then the tag/text is not found.
      Can anyone help? It is a useful expression to have if you are trying to transfer applications developed on a windows machine to a, say, linux machine, and have table name sensititvity issues with mySql.
        • 1. Re: Find text between tags with regular expression
          Level 7
          You should be OK by simply not specifying the ending of the opening
          <cfquery> tag:
          <cfquery.*(EventName|AttendeeName).*</cfquery>
          I doubt your table names will occur *between* the "<cfquery" and its ">",
          so it should be safe to assume any matches are within the SQL string.
          I'm not sure you need to be so precise with the CFQUERY capitalisation, but
          I guess you have your reasons.
          Adam
          • 2. Re: Find text between tags with regular expression
            Ortho Level 1
            Thanks, but it:
            1) Captures everything between the first and last query in a script if there is more than one cfquery in the script
            2) It produces some regular expression errors in Homesite.
            The reason for this is I am developing on a windows machine with mysql and want to use the application online on a linux machine where table names are case sensitive. My code was not always faithful to that since in windows you can be sloppy!
            • 3. Re: Find text between tags with regular expression
              Level 7
              > Thanks, but it:
              Oops: sorry. Stick a question mark after the asterisks to stop the matches
              being greedy.
              Can't help you there. Sounds like HS's regex processor is bung: there's
              nothing non-standard or tricky about that regex (which might cause
              compatibility issues; JS vs PERL vs Java, etc).
              HS on the whole is bung (IMO). Have you considered using a text editor
              that is... err... *current*? ;-)
              What sort of errors is it giving?
              > can be sloppy!
              Have you seen this:
              http://dev.mysql.com/doc/refman/5.0/en/identifier-case-sensitivity.html
              It might be a better approach anyhow.
              Adam
              • 4. Re: Find text between tags with regular expression
                Ortho Level 1
                quote:
                Originally posted by: Newsgroup User
                Thanks for all the help. Comments below.
                > Thanks, but it:
                being greedy.
                Used this:
                <[Cc][fF][qQ][uU][eE][rR][Yy].*?(EventName|AttendeeName)[^>].*?</[Cc][fF][qQ][uU][eE][rR][ Yy]>
                and got some finds again with multiple queries and some errors as mentioned below.
                No, can you suggest one. Just use HS for years and it does most of what I want.
                Regular expression error No 17. Bad expression format or internal error.
                > can be sloppy!
                Have you seen this:
                Adam
                • 5. Re: Find text between tags with regular expression
                  Level 7
                  > ][eE][rR][Yy]>
                  > below.
                  Maybe drop the [^>]
                  Eclipse is probably the best option at present (all still IMO, obviously).
                  It seems to be where Adobe is applying their efforts for CF and Flex
                  development.
                  Not so helpful then. I'm guessing "internal error" more than "bad format",
                  though.
                  > Have you seen this:
                  Did you look at this?
                  Adam
                  • 6. Re: Find text between tags with regular expression
                    Ortho Level 1
                    > ][eE][rR][Yy]>
                    > below.
                    Maybe drop the [^>]
                    Makes no difference. The original I had still works the best.
                    development.
                    though.
                    > Have you seen this:
                    Yes, and I think I know all the alternatives now -- just have to find those problem table names and do the grunt work! Thanks for all your suggestions.
                    Adam
