6 Replies Latest reply on Apr 27, 2010 9:20 PM by Vikash.kumar29
    Measuring the width of an HBox
    SiHoop Level 1
      I am adding a button to an HBox. The button is of variable length and I want to get the width of the HBox each time a new button is added.
      1. How can I get the width of the HBox each time a button is loaded?
      2. How can I add the buttons to the HBox so they are placed end-to-end horizontally (i.e. no spaces between the buttons)?
      Thank you!
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" applicationComplete="init()">
          <mx:Script>
        <![CDATA[
            import mx.events.ChildExistenceChangedEvent;
      import mx.controls.Button;
      private var button:CustomButton;
      public function init():void{
          for(var j:int=0; j<5;j++){
              button=new CustomButton
              buttonsContainer.addEventListener(Event.ADDED, getLength)
              buttonsContainer.addChild(button)
      public function getLength(e:Event):void{
          trace("length="+e.target.width)
      </mx:Script>
            <mx:HBox id="buttonsContainer" horizontalCenter="0" verticalCenter="0"/>
      </mx:Application>
      CustomButton.mxml
      <mx:Button xmlns:mx="http://www.adobe.com/2006/mxml"    creationComplete="init()">
      <mx:Script>
        <![CDATA[
          this.width=Math.floor(Math.random()*50)+50
      </mx:Script>
      </mx:Button>
        • 1. Re: Measuring the width of an HBox
          Vikash.kumar29 Level 3
          For you problem
          you can use
               buttonsContainer.validateSize(true);
               trace(buttonsContainer.getExplicitOrMeasuredWidth())
          and for your problem
          You can set the horizontalGap of HBox to 0, so that no horizontal gapping will be used during layout of container.
          Hope this is what you are looking for.
          Cheers
          -Vikash
          • 2. Re: Measuring the width of an HBox
            SiHoop Level 1
            I tried your solution but it didn't work. It returned a value of 0.
            Could it be that a different event handler is needed?
            Thanks very much for the info about horizontalGa-- that was perfect!
            • 3. Re: Measuring the width of an HBox
              Try using Following code
              buttonsContainer.addEventListener(ChildExistenceChangedEvent.CHILD_ADD, getLength) in Application init function which must lookLike
                  <mx:Script>
                       <![CDATA[
                             import mx.events.FlexEvent;
              </mx:Script>
              </mx:Application>
              and modify your CustomButton.mxml as
              <mx:Button xmlns:mx="http://www.adobe.com/2006/mxml"    preinitialize="init()">
              <mx:Script>
                <![CDATA[
                  this.height = 22;
              </mx:Script>
              </mx:Button>
              Hope this helps you out
              Cheers
              -Vikash
              • 4. Re: Measuring the width of an HBox
                SiHoop Level 1
                Perfect! Thanks so much.
                • 5. Re: Measuring the width of an HBox
                  SiHoop Level 1
                  Vikash,
                  I've found one problem with your code: The first time through it returns a value of 0. Is there a way to prevent it from firing the listener until after the component has been added to the display. It looks to me as though the trace value is always one instance behind.
                  Thanks again!
                  • 6. Re: Measuring the width of an HBox
                    Yes, coz I think at that point of time button's creationComplete is not completed. So instead adding
                    Try using
                                                button.addEventListener(FlexEvent.CREATION_COMPLETE,
                    getLength);
                    Hope, this may result into correct calculations.
