6 Replies Latest reply on Apr 28, 2010 5:48 AM by lisakuepper
    Problem to log in
    lisakuepper
      Hi there,
      I have installed a LiveCycle ES2 and a LiveCyle Workbenche ES on one windows server 2008 "A" and a LiveCycle Workbenche ES on another windows server 2008 "B" as well. Both of them are in our company domaem. But when I want to login in with Workbenche ES from server "B" to CliveCycle on server "A".  I get failure message, that I should check the netzwerk connetion setting.
      I have ever shout down firewall, and checked the DNS-ip. I can use the same user data to login with the workbenche on server "A", it means, the user data was right. I have run the workbenche as administrator.
      Where I could still check. What could be the reason. Could sombady help?! thanks very much!!
      Best regards
      Lisa
        • 1. Re: Problem to log in
          Jasmin Charbonneau Level 4
          What are you setting you connection to?
          Try to use the IP address of server A in your connection settings.
          Jasmin
          • 2. Re: Problem to log in
            lisakuepper Level 1
            Hi Jasmin,
            thanks for this answer. But it is not  clear enough for me. Which connection setting did you mean? Is that on  the login screen, where I can manage configured servers? If that is what  you meant, I set already the IP address of the server A. Or maybe you  mean somewhere else?
            Best regards
            Lisa
            • 3. Re: Problem to log in
              Yes. I meant the connection from the login page.
              What operating system are you using on server A?
              Jasmin
              • 4. Re: Problem to log in
                lisakuepper Level 1
                The OS on the server A is Windows Server 2008 R2 and the OS on the server B is Windows Server 2008.
                Lisa
                • 5. Re: Problem to log in
                  That's what I was afraid of.
                  I ran into a similar problem trying to access adminui on a Windows 2008 server and that's because Win 2008 server block a bunch of ports.
                  I had to run a script I found somewhere on the web to open the ports.
                  You probably don't need to open them all up. I added 8080 and 8443 in the script and just ran it in a Command window and that fixed my problem.
                  Here's the script:
                  @echo =========  SQL Server Ports  ===================
                  @echo Enabling SQLServer default instance port 1433
                  netsh firewall set portopening TCP 1433 "SQLServer"
                  @echo Enabling Dedicated Admin Connection port 1434
                  netsh firewall set portopening TCP 1434 "SQL Admin Connection"
                  @echo Enabling conventional SQL Server Service Broker port 4022
                  netsh firewall set portopening TCP 4022 "SQL Service Broker"
                  @echo Enabling Transact-SQL Debugger/RPC port 135
                  netsh firewall set portopening TCP 135 "SQL Debugger/RPC"
                  @echo =========  Analysis Services Ports  ==============
                  @echo Enabling SSAS Default Instance port 2383
                  netsh firewall set portopening TCP 2383 "Analysis Services"
                  @echo Enabling SQL Server Browser Service port 2382
                  netsh firewall set portopening TCP 2382 "SQL Browser"
                  @echo =========  Misc Applications  ==============
                  @echo Enabling HTTP port 80
                  netsh firewall set portopening TCP 80 "HTTP"
                  @echo Enabling HTTP port 8080
                  netsh firewall set portopening TCP 8080 "JBoss"
                  @echo Enabling SSL port 443
                  netsh firewall set portopening TCP 443 "SSL"
                  @echo Enabling SSL port 8443
                  netsh firewall set portopening TCP 8443 "JBoss SSL"
                  @echo Enabling port for SQL Server Browser Service's 'Browse' Button
                  netsh firewall set portopening UDP 1434 "SQL Browser"
                  @echo Allowing multicast broadcast response on UDP (Browser Service Enumerations OK)
                  netsh firewall set multicastbroadcastresponse ENABLE
                  Jasmin
                  • 6. Re: Problem to log in
                    lisakuepper Level 1
                    Hi Jasmin,
                    thanks very much!! I have tried the script and it works.
                    Best regards
                    Lisa
