0 Replies Latest reply on Apr 26, 2010 9:16 AM by Paul Reilly
    [svn:fx-trunk] 15702: * Package and class level javadoc for the
    Paul Reilly Level 1
      Revision: 15702
      Revision: 15702
      Author:   preilly@adobe.com
      Date:     2010-04-26 09:16:12 -0700 (Mon, 26 Apr 2010)
      Log Message:
      • Package and class level javadoc for the
        flex2.compiler.[css,extensions,fxg,i18n,io] packages.  Includes some
        dead code removal.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/ConditionTypeNotSupported.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Import.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/ParseError.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Reference.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/SelectorTypeNotSupported.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleConflictException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Styles.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/UnqualifiedTypeSelector.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/UnresolvedQualifiedTypeSelect or.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionManager.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionsConfiguratio n.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IApplicationExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ICompcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IConfigurableExtension .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ILibraryExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IMxmlcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreCompileExtension.j ava
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreLinkExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGSymbolClass.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexResourceResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nUtils.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyText.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyTranslationFormat.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/TranslationException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/TranslationFormat.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/TranslationInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/DeletedFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/FileUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/InMemoryFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/LocalFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/NetworkFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/ResourceFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/TextFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/VirtualFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/VirtualZipFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/ZipFileHolder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/io/package.html
      Removed Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/util/ListMap.java
