2 Replies Latest reply on Apr 26, 2010 5:05 PM by Michael Thornburgh
    Issue connecting to Vista peer from OS X, XP and Windows 7
    dccwilliams Level 1
      Hi, I've got the following problem.
      Got a bunch of OS X, XP, Vista and Windows 7 machines sitting on standard NetGear LAN. The router has a static IP and is running NAT for the clients. There is a firewall to Internet (Firebrick).
      There are no problems connecting between the OS X, XP, Windows 7 machines. However, you cannot connect to the Vista peers, except in some special cases.
      To simplify I'm using the standard file sharing example. Calling the following method:
      private function connectReceiveStreamToPeer(e:Event):void
      recieveStream = new NetStream(netConnection,txtFarID.text);
      recieveStream.client = this;
      recieveStream.addEventListener(NetStatusEvent.NET_STATUS, receiveStreamHandler);
      recieveStream.play("file");
      where txtFarID.text represents a Vista peer, never results in the receive stream becoming connected to the Vista peer's sendStream...
      However, there is a connection. If the Vista peer first connects its receiveStream to the sendStream of the OS X, XP or Windows 7 peer, then the OS X, XP or Windows 7 peer is thereafter able to connect its receiveStream to the sendStream of the Vista peer.
      I've tested this on a couple of Vista laptops. Both are completely standard and don't have any special security software installed.
      Any ideas?
      Best, Dominic
