0 Replies Latest reply on Apr 26, 2010 12:44 PM by Carol L. Frampton
    [svn:fx-4.x] 15707: Two changes to RichEditableText' s setLayoutBounds override:
    Carol L. Frampton Level 2
      Revision: 15707
      Revision: 15707
      Author:   cframpto@adobe.com
      Date:     2010-04-26 12:43:51 -0700 (Mon, 26 Apr 2010)
      Log Message:
      Two changes to RichEditableText's setLayoutBounds override:
      1)  widthConstraint and heightConstraint should be reset in setLayoutBounds() rather than updateDisplayList().  setLayoutBounds() is only called when the measured size changes which means that it is not necessarily called before each call to updateDisplayList().  Recycled item renders exposed this flaw.
      2) Should be setting widthConstraint and heightConstraint each time to either NaN or the value of the constraint regardless of the value of autoSize.
      QE notes:
      Doc notes: None
      Bugs:  SDK-26298, SDK-26178
      Reviewed By: Gordon
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26298
          http://bugs.adobe.com/jira/browse/SDK-26178
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/RichEditableText.as
