7 Replies Latest reply on Apr 27, 2010 11:08 AM by hans-g.
    Hello
    cablegirl22
      I have been building sites in dreamweaver for awhile now.
      I am in CS4
      But I have never been able to figure this out.
      I am using 2 templates and I only want certain links to change colors
      When I make a word a certain color I dont want it to change colors even if it is a link
      Some of my links are not changing but then the ones that are white text are showing up blue when I link them.
      Its frustrating
      Please Help
        • 1. Re: Hello
          hans-g. Adobe Community Professional & MVP
          please have a look to your the link in your source code. Here you will find something like that:
          <a href="YourSite.php"><span class="Stil5">
          Complete the entry as follows:
          <a href="YourSite.php"><span class="Stil5" style="color:#FFFFFF"> or of course an other color code.
          Hans-G.
          P.S.
          Your subject line "Hello", hm.
          • 2. Re: Hello
            cablegirl22 Level 1
            Thank You, but I am not having any luck
            Here is the line of code
            [Home | ../index.html]
            I cannot get it to work
            Would you please show me what it should be
            Thank You
            • 3. Re: Hello
              it doesn't look like a source code. Could you please send me a link to your website, or if not possible your source code?
              But I've forgotten: look to the preferences (here from german DW):
              Here you can change the links's color.
              Hans-G.
              Nachricht aktualisiert durch hans-g.
              • 4. Re: Hello
                cablegirl22 Level 1
                Hello Hans
                The website address is
                http://www.beads2rhinestones.com/rhinestone-flatbacks/rhinestones-flatback-styles.html
                See the word Home once I make it a link to another page it changes to blue
                However the other links on that page like the sentence doesn't change to blue and it is a link
                Swarovski Round Flatbacks
                I appreciate your help
                Sandy
                • 5. Re: Hello
                  Hi Sandy,
                  I succeeded changing "Home" into white color. Actually, I did what I advised with: "look to the preferences ...(Page Properties)"
                  But 'till you can do this, you have to remove the the non-editable areas of your template, which appear in source code in a light gray. Written is something like: <! - InstanceEndEditable ->. There where you can change an entry completely unproblematic is the editable region between:
                  <!-- InstanceBeginEditable name="Here is something written, like title aso" -->
                  and
                  <!-- InstanceEndEditable -->
                  One way is: Talk about the change with the creator of the template.
                  But now back to my approach:
                  I deleted all these these <!-- and --> in your source code (it's a sledgehammer method of course).
                  Copied the source code in a simple txt-editor.
                  Changed and deleted all these <!-- and -->, you can't edit otherwise.
                  Then went back with the contents into a really new and blank DW-file (that means I deleted all entries in my source code before I copied the changed text file).
                  Changed the link colore to white (page properties)
                  DW completed the path like this:
                  <td width="145" align="center" valign="bottom" class="style56"><a href="http://www.beads2rhinestones.com/index.html">Home</a></td>
                  And now look here:
                  Home has changed from blue to white. Of course, you have to delete all these entries in your source code: <!-- InstanceBeginEditable name="title" --> and <!-- InstanceEndEditable -->.
                  Hans-G.
                  • 6. Re: Hello
                    cablegirl22 Level 1
                    Thanks Hans.
                    • 7. Re: Hello
                      Hi Sandy,
                      as I can see you made the home white already. Did you use a different way? If yes, I would like to know how, naturally.Hans-G.
