6 Replies Latest reply on Apr 27, 2010 10:27 AM by breadmanorange
    Swapping images that have image maps
    breadmanorange
      Using RoboHelp 8, I'm embedding images and adding half a dozen image map shapes with links to distant topics in my help project. Every time I modify an image, it seems I have to swap it out with the image I put in previously (unlike, say, in InDesign, where you can create an automatically updating link to an image). And every time I delete the image, the maps disappear and need to be re-created.
      1. Is there a way to link images in RoboHelp to avoid the manual delete and replacement?
      2. Is there a way to store image maps so they needn't be re-created every time their underlying image is replaced?
      Thanks much.
        • 1. Re: Swapping images that have image maps
          Hi there
          The key here is to avoid using RoboHelp to replace the image.
          If you simply replace the image using Windows Explorer and using the same file name, the map areas will be retained. RoboHelp should be none the wiser. If the dimensions of the image changed during editing, you will need to right-click the image and choose Reset Size. But the map areas should still be present.
          Cheers... Rick
          Helpful and Handy Links
          RoboHelp Wish Form/Bug Reporting Form
          Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
          Adobe Certified RoboHelp HTML Training
          SorcerStone Blog
          RoboHelp eBooks
          • 2. Re: Swapping images that have image maps
            breadmanorange Level 1
            Rick,
            I'm not seeing it. My workflow is that I created the initial gif image from Microsoft Visio, inserted the image into a topic and saved it. Then I modify the image in Visio, save with the same name, replacing the file in the same location, then I generate my project again in RoboHelp and the old image is still in place.
            What must I do to tell RoboHelp to refresh the image?
            • 3. Re: Swapping images that have image maps
              Hi again
              Sorry, but it looks like you are bowling me a wobbly.
              I thought you said you were losing the map regions. Now you are saying the image isn't updating to reflect changes.
              Which is the actual issue?
              Assuming the update simply saved the image in the same location from where it came, you should be seeing the updated image. As long as the image exists where RoboHelp thinks it should. If you aren't seeing the update it means one of a few things.
              • You aren't actually looking at the updated help
              • You aren't actually updating the correct image in the correct location
              • You may be confused about which topic has the image (although I find that unlikely)
              Cheers... Rick
              SorcerStone Blog
              RoboHelp eBooks
              • 4. Re: Swapping images that have image maps
                Rick,
                The answer is both: I'm trying to update the image and have the image maps remain in place. I'll give you more detail.
                In Visio, I create the SampleDraw image and save a gif copy of it into my RoboImages folder (SampleDraw.gif). I quit Visio.
                In RoboHelp, I create topic SampleTopic and insert image SampleDraw.
                I create a few image maps on top of SampleDraw in SampleTopic.
                I save my RoboHelp project and quit.
                Now I open SampleDraw in Visio, make some changes, and save it as SampleDraw.gif in my RoboImages folder. I get a message warning me that an existing drawing of the same name in the same location exists. I OK the overwrite, and the old SampleDraw.gif is gone, replaced by my modified gif of the same exact name.
                I open my RoboHelp project and launch SampleTopic. The old images is there, and the image maps are also in place.
                • 5. Re: Swapping images that have image maps
                  Rick,
                  Sorry, some weirdness happened and my last post got posted before I finished.
                  Here's a more detailed scenario.
                  I open Microsoft Visio and create SampleImage. I save it as a gif to my RoboDrawings folder. Now, in the RoboDrawings folder, there is an image called SampleImage.gif.
                  I quit Microsoft Visio.
                  I open RoboHelp and create a project in which a topic is called SampleTopic.
                  I insert an image, go to the RoboDrawings folder and select SampleImage.gif.
                  I create a few image maps linking to various other topics.
                  I save everything, generate html help and close down RoboHelp.
                  Now I open Microsoft Visio again, open SampleImage and change it drastically without resizing anything.
                  I save my Visio drawing under the same name, perform a Save As and go to the RoboDrawings folder to save the image as SampleImage.gif. I get a message warning me a file of the same name exists, and I choose to overwrite it, eliminating the old file.
                  I shut down Visio.
                  I open RoboHelp, view SampleTopic and the old image is there with image maps in place. I generate html help again, and the old image is still there with its maps in place.
                  Without deleting the old image in the SampleTopic and manually inserting the new one (same name, though), how do I get RoboHelp to acknowledge that the image has been updated?
                  • 6. Re: Swapping images that have image maps
                    Rick,
                    I found the answer.
                    Instead of going to the RoboHelp menu and pulling down Insert-Image again, I have to right click on the image, select Image Properties and, up in the image name field, select the "select image file" button. Then I choose the exact same image and it updates while leaving the image maps in place.
                    Thanks for your help.
                    Brad
