7 Replies Latest reply on Dec 8, 2010 1:20 PM by JackFreudenheim
    ORM CFC Wizard shows up blank
    bdensmore12673 Level 1
      I'm trying out the ORM CFC Wizard from a table in my RDS Dataview. When I do this I get the option to select where I want the CFC created and the checkbox to create the CFC in script.
      Once I click OK, the next screen is blank.
      I've searched through the forums and found some suggestions of turning off debugging and renaming all references to "Framework" to "framework".
      I've made sure debugging is turned off and went through and made sure all references to "Framework" are all lowercase with no luck.
      Has anyone been able to fix this issue with success?
      I'm running CF 9 on JBOSS 5.2 on OS X 10.6.3 if that helps any. RDS works fine as I can see my datasources.
      One thing I noticed, if I refresh the ORM Wizard screen it does generate a premature end of file error on the XML. But this error doesn't happen on the first try.
      Ben
        • 1. Re: ORM CFC Wizard shows up blank
          Joe31371283 Level 1
          Hello,
          Did you ever resolve this issue...I am having the same problem.
          Mac OS X 10.6
          Coldfusion builder 1 with update 1
          When I right-click "Reload" I get a big dump:
          coldfusion.xml.XmlProcessException: An error occured while Parsing an XML document. at coldfusion.xml.XmlProcessor.parse(XmlProcessor.java:183) at coldfusion.runtime.Cast._Xml(Cast.java:1345) at coldfusion.tagext.validation.CFTypeValidatorFactory$CFXMLValidator.validate(CFTypeValidat orFactory.java:425) at coldfusion.runtime.UDFMethod.validateValueType(UDFMethod.java:182) at coldfusion.runtime.UDFMethod._validateArg(UDFMethod.java:1072) at coldfusion.runtime.UDFMethod._validateArg(UDFMethod.java:1089) at cfRequestProcessor2ecfc1904329852$funcPARSEREQUEST.runFunction(/Library/WebServer/Documen ts/Adobe CFC Generator/handlers/framework/RequestProcessor.cfc:14) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.filter.SilentFilter.invoke(SilentFilter.java:47) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:517) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:495) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:354) at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2301) at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:375) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2723) at cfORMManager2ecfc1990215907$funcLOADTABLES.runFunction(/Library/WebServer/Documents/Adobe CFC Generator/handlers/framework/ORMManager.cfc:265) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:517) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:495) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:354) at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2301) at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:382) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2723) at cflayoutpage2ecfm1151129293.runPage(/Library/WebServer/Documents/Adobe CFC Generator/handlers/layoutpage.cfm:37) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2722) at cfApplication2ecfc1209604170$funcONREQUEST.runFunction(/Library/WebServer/Documents/Adobe CFC Generator/handlers/Application.cfc:84) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472) at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:405) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:220) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:490) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:336) at coldfusion.runtime.AppEventInvoker.invoke(AppEventInvoker.java:88) at coldfusion.runtime.AppEventInvoker.onRequest(AppEventInvoker.java:280) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:338) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:87) at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53) at coldfusion.CfmServlet.service(CfmServlet.java:200) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at jrun.servlet.FilterChain.doFilter(FilterChain.java:86) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 ) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at jrun.servlet.FilterChain.service(FilterChain.java:101) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543) at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
          • 2. Re: ORM CFC Wizard shows up blank
            JackFreudenheim Level 1
            I'm having the same problem on CF Builder as a plugin to Flash Builder 4.
            Running standalone CF Builder, it works fine.
            Does anyone have an answer for this?
            • 3. Re: ORM CFC Wizard shows up blank
              bdalton Level 1
              I'm having the same issue.
              I get the prompt to select a location and if I want a script-based cfc... after that, it's blank. If I right-click and reload the content, I get this:
              http://screencast.com/t/okhY2hjbS9
              This is on a standalone CF Builder install on Mac OS. I've tried an uninstall and reinstall, all without luck.
              Ben
              • 4. Re: ORM CFC Wizard shows up blank
                Oddly, it works for me within Flash Builder 4 after I installed ColdFusion Builder as a plugin, but still won't work in CF Builder.
                I'm giving up on ORM for now anyway, it's been a pain to use it for all but the simplest things, and there's so little documentation available that it seems hopeless for now.  I spent hours trying to get a create operation to work with an identity column in Sql Server, to no avail.
                • 5. Re: ORM CFC Wizard shows up blank
                  Gregory Fischer Adobe Employee
                  I too experienced the blank ORM generator UI on my Mac, but there was an easy fix for me.
                  In ColdFusion Builder
                  • Goto preferences->ColdFusion->Extensions.
                  • Check the option to use Mozilla as browser for extensions.
                  After doing this I was able to create ORM cfc files as expected.
                  Hope that helps.
                  G
                  • 6. Re: ORM CFC Wizard shows up blank
                    bdalton Level 1
                    Wow, This worked for me. Thanks!
                    • 7. Re: ORM CFC Wizard shows up blank
                      Hey thanks for pointing that out! In my case, it was by UNchecking "use mozilla" that did the trick, and showed me why it was working in FB and not CFB.
                      Thanks again,
                      Jack
