2 Replies Latest reply on Apr 30, 2010 8:40 PM by FTQuest
    multilinelabel or Using the \n key for a label in the Tabbar
    mxvx
      Hi
      Can I have a tabbar label with 2 lines.
      For eg. _______________
                |  Adobe   |   Tab   |
                |    Flex    |    2      |
                |________| ______|
      Can I have such a label in tab bar.
      I actually use a tab navigator from http://groups.google.com/group/flexlib/browse_thread/thread/7e9d36d7d5a352fd/0eec90d460883 666
      I am unable to have a multiline tab. I tried overriding the createchildren method but nothign works out ?? Any solutions?
      Thanks & Regards
      mxvx
        • 1. Re: multilinelabel or Using the \n key for a label in the Tabbar
          mxvx Level 1
          thanks to harui and google.  The final solution which resolved the problem. At many sites it has been mentioned to override the createChildren() method but from harui's site, i took both the measure and measureText methods. It was working fine .Wud be fine if they would have explained the functionalities too.
          http://blogs.adobe.com/aharui/2007/04/multiline_buttons.html
          protected
          override function createChildren():void {
          if (!textField)
          textField =
          new UITextField();
          textField.styleName =
          this;
          addChild(DisplayObject(textField));
          super.createChildren();
          textField.multiline =
          true;
          textField.wordWrap =
          true;
          this.setStyle("textAlign","left");
          width = 150;
          //height = 100;
          override protected function measure():void
          if (!isNaN(explicitWidth))
          var w:Number = explicitWidth;
          textField.width = w;
          super.measure();
          override public function measureText(s:String):TextLineMetrics
          textField.text = s;
          var lineMetrics:TextLineMetrics = textField.getLineMetrics(0);
          lineMetrics.width = textField.textWidth + 4;
          lineMetrics.height = textField.textHeight + 4;
          return lineMetrics;
          Thanks & Regards
          mxvx
          • 2. Re: multilinelabel or Using the \n key for a label in the Tabbar
            FTQuest Level 3
            There are shorter solutions; e.g.
            <s:Label text="First line{'\n'}Second line" />
            <s:Label text="Third line&#13;Fourth line" />
            or you can just put the number of lines you need in the skin file.
            HTH,
            FTQuest
