0 Replies Latest reply on Apr 27, 2010 9:28 PM by Paul Reilly
    [svn:fx-trunk] 15781: * Package and class level javadoc for the flex2. compiler.swc and
    Paul Reilly
      Revision: 15781
      Revision: 15781
      Author:   preilly@adobe.com
      Date:     2010-04-27 21:27:51 -0700 (Tue, 27 Apr 2010)
      Log Message:
      • Package and class level javadoc for the flex2.compiler.swc and
        flex2.compiler.util packages and their subpackages.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Digest.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcComponent.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDependencySet.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcFeatures.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcFile.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcGroup.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLazyReadArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcMovie.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcPathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcScript.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcWriteOnlyArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Versions.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/CatalogReadElement.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/CatalogReader.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/CatalogWriter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/ReadContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/AbstractLogger.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Benchmark.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/CompilerControl.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ConsoleLogger.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/DualModeLineNumberMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/IteratorList.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/LineNumberMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/LinkedQNameMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ManifestParser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MultiNameMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/NameFormatter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/NameMappings.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/OrderedProperties.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/PerformanceData.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/PrefixMapping.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameList.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QNameSet.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyInfoImpl.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcDependencyUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcExternalScriptInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/SwcExternalScriptInfoImpl.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ThreadLocalToolkit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/TraceExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/URLPathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/VelocityException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/VelocityManager.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/XMLStringSerializer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Algorithms.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/DependencyGraph.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Edge.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Graph.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Vertex.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/Visitor.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/zip/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/graph/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/package.html
