3 Replies Latest reply on Sep 14, 2007 8:31 PM by Newsgroup_User
    Insert table/image not working correctly
    pda4me
      Okay, I am going nuts here...When i try to insert a table or image using the Insert toolbar it just plops down a default <img> tag like this <img src="" /> or a default table with a single column and two rows...before it would open up a dialog to choose the image or configure the table properties. How do I change this back to do this by default?
      Thanks!
        • 1. Re: Insert table/image not working correctly
          Level 7
          Are you inserting in Code view? Try doing it in Design view....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "pda4me" <webforumsuser@macromedia.com> wrote in message
          news:fcbdo5$ld8$1@forums.macromedia.com...
          > the
          > src="" />
          > open up
          > Thanks!
          • 2. Re: Insert table/image not working correctly
            Level 7
            That's the behavior I get when I hold down the Ctrl key while inserting
            an object. Is that what you're doing?
            Randy
            • 3. Re: Insert table/image not working correctly
              Level 7
              You can get that behavior also if you have unchecked:
              Edit -> Preferences -> General -> Editing Options -> Show Dialog when inserting objects.
              Danilo Celic
              | Extending Knowledge Daily : http://CommunityMX.com/
