0 Replies Latest reply on Sep 17, 2007 8:51 AM by Olthrion
    Importing fl.
    Olthrion Level 1
      Have just started to test out the new AS3 and so far it have been okay, until now.
      Before I have used "import flash.<something>" and it have worked fine, but now I have wanted to use "import fl.<something>
      But here comes the problem, none of them work.
      Do you have to import fl. in another way then when you import flash.?
      Would be strange so I figure the answer on that question to be no.
      But how can I fix it then since it seems like everything under fl. is gone and I keep getting errors like: 1172: Definition fl.containers:UILoader could not be found.
      Others here have the same problem and that seems a bit strange.
      Is there others out there that get the same error?
