3 Replies Latest reply on Apr 29, 2010 12:00 AM by Adobe-InDesign CS4
    Removing unassociated Xml elements from structure
    Marco Lugli Level 1
      Hello, I use Indesign CS3,
      I have a document containing a series of xml elements: some of these are associated with some graphic elements on the page and some are not.
      is there a way to remove all unassociated xml elements from the structure of this document by javascript?
      I tried this:
      main();
      function main(){
          var myDocument = app.activeDocument;
          var myRootXmlElement = myDocument.xmlElements.item(0);
          var myXmlElements = myRootXmlElement.xmlElements;
          function deleteUnassociated(){
              for(i = 0; i < myXmlElements.length; i++){
                  var myXmlElement = myXmlElements[i];
                  if(myXmlElement.xmlContent == null){
                      myXmlElement.remove();
          deleteUnassociated();
      but with no results..
      Any suggestions?
        • 1. Re: Removing unassociated Xml elements from structure
          Adobe-InDesign CS4 Level 1
          Dear Macro,
          Please use the below script....
          ///=========================== Start ====================//
          //    var myRootXmlElement = myDocument.xmlElements.item(0);
              //var myXmlElements = myRootXmlElement.xmlElements;
          deleteUnassociated(myDocument)
              function deleteUnassociated(elm){
                  for(var i = 0; i < elm.xmlElements.length; i++){
                      var myXmlElement = elm.xmlElements[i];
                          elm.xmlElements[i].remove();
              deleteUnassociated(elm.xmlElements[i]);
          ////====================== End =====================//
          Regards
          T.R.Harihara Sudhan
          • 2. Re: Removing unassociated Xml elements from structure
            Marco Lugli Level 1
            Sorry Harihara,
            but it doesn't work..
            • 3. Re: Removing unassociated Xml elements from structure
              Dear Macro.
              var myDoc  = app.activeDocument;
              //============================Start ============================//
              Check(myDoc);
              function Check(elm)
                  try
                       for(var i=0; i<elm.xmlElements.length; i++)
                             myXMLElement = elm.xmlElements[i];
                             if((myXMLElement.contents == "") || (myXMLElement.contents == null) || (myXMLElement.contents == undefined))
                               Check(elm.xmlElements[i]);
                        }catch(e)
                              exit(0);
              //===================================== End ============================//
              Pls. use the above one...
              Regards
              T.R.Harihara Sudhan
