4 Replies Latest reply on Apr 28, 2010 7:51 AM by William-01
    P versus H1
    William-01
      What is the proper way to handle this.
      <body>
      <h1>This is where I will put the main copy.<br />The copy will continue on this line.</h1>
      <h2>Additional copy will go here. <em>Part of it is bold?</em></h2>
      </body>
      </html>
      Is it more appropriate to  use a <p> for the second line and <em> or <b> to make "Part of it is Bold" stand out more and then increase the text-size?
      Ideally I would like both lines to act as a heading, but having control of the "Part of it is Bold".
      I just don't what the proper structure is i.e. can I use two heading tags as I am doing or do I need to use <p> and adjust font size and format.
      william-01
        • 1. Re: P versus H1
          osgood_ Level 8
          <body>
          </body>
          </html>
          william-01
          h1, h2, h3 are used for headings.
          So you need to identify your headings in order of importance and use logical text.
          <h1>Most important heading</h1>
          <p>Text which relates to most important heading<p>
          <h2>Less prominant heading</h2>
          <p>Text which relates to less prominant heading</p>
          Yes you can use a <br /> (if required but not an awfully good idea where text would normally just run on)
          <h1>Most important<br /> heading</h1>
          Use <strong></strong> to enbolden text sections.
          <p>The company produces <strong>highly acclaimed</strong> music videos</p>
          • 2. Re: P versus H1
            William-01 Level 1
            Can headings be on more than one line?
            For example, if I want my heading to be a punch list of items. Coffee, Beer, Milk, Juice etc. For the purposes of layout and design, can I stack a heading using <br /> or are you saying heading should be all on one line?
            I'm just trying to understand the proper structure.
            • 3. Re: P versus H1
              osgood_ Level 8
              A list of items is a list NOT a heading.
              Here's the difference
              <h1>We are suppliers of coffee, beer, milk and juice<h1> (could be a prominant heading to inform what you supply)
              Coffee
              Beer
              Milk
              Juice
              is to my thinking just a plain list and as such you would use an unordered list for layout purposes:
              <ul>
              <li>Coffee</li>
              <li>Beer</li>
              <li>Milk</li>
              <li>Juice</li>
              <ul>
              Headings don't have to be on one line but placing a <br /> in the structure is manipulating the layout into a list structure which is not a heading, it's a list
              • 4. Re: P versus H1
                William-01 Level 1
                Got it!
                So much to learn about proper formating. I appreciate your patience.
