8 Replies Latest reply on Apr 28, 2010 9:24 AM by 66jonez
    Looping one 10 second sound file.. saaaave meeee!!
    66jonez Level 1
      Ok...  so I am a newbie to flash pretty much.  So forgive me in advance.  I
      am trying to loop a small sound file (wav file because I was told wav will loop seemlessly)...
      in any case, got the actionscript (2.0) to work with one simple button that acts as a
      start and pause...  but yet, the file still doesnt loop.
      Does anyone have an actionscript that accomplishes this that I can take a peek at?  I HAVE to be missing something small..  its driving me nuts.
      It just will not loop.
      Thanks a ton.
      Dann
        • 1. Re: Looping one 10 second sound file.. saaaave meeee!!
          Can you describe the details of steps you took to create this and include the code you are using?
          • 2. Re: Looping one 10 second sound file.. saaaave meeee!!
            66jonez Level 1
            Here's the code...
            var snd:Sound = new Sound();      //Create a new sound object
            var sndFile:String;
            var sndPlaying:Boolean = true;      //Status flag indicating whether the sound is playing or not
            var sndFinished:Boolean = false;     //Status flag indicating whether the sound has finished playing or not
            var startVolume:Number;        //Start value of sound volume
            var autoStart:Boolean;
            //Extract the sound file name from the calling object
            if (this.sndfile != undefined) {
            sndFile = this.sndfile;
            else {
            //Default setting is "songnamehere".mp3
            sndFile = "pinknoise.mp3";
            if(this.sndvol != undefined) {
            startVolume = int(this.sndvol);
            } else {
            startVolume = 50;
            if (this.sndautostart == 0) {
            autoStart = true;
            } else {
            autoStart = false;
            snd.loadSound(sndFile, true);     //Load the specified sound file and start streaming
            snd.setVolume(startVolume);       //Set initial sound volume
            if(autoStart != true) {
            snd.stop();
            sndPlaying = false;
            sndFinished = true;
            mcPlay._visible = true;
            mcPause._visible = false;
            } else {
            sndPlaying = true;
            sndFinished = false;
            mcPlay._visible = false;
            mcPause._visible = true;
            stop();
            snd.onSoundComplete = function() {
            sndPlaying = false;
            sndFinished = true;
            mcPlay.onRelease = function() {
            if(sndPlaying != true) {
              if(sndFinished == true) {
               //Start playing the sound from the beginning
               snd.start(0,999999999999999999999);
              } else {
               //Start playing the sound only if it was previously paused
              sndPlaying = true;
            mcPause.onRelease = function() {
            //Pause sound playing
            snd.stop();
            sndPlaying = false;
            • 3. Re: Looping one 10 second sound file.. saaaave meeee!!
              If you are streaming the sound, you cannot specify looping for it... per the help documents...
              loops:Number [optional] - A parameter that lets you specify the number of times the sound should play consecutively. This parameter is not available if the sound is a streaming sound.
              • 4. Re: Looping one 10 second sound file.. saaaave meeee!!
                66jonez Level 1
                I do not want to stream this file...
                • 5. Re: Looping one 10 second sound file.. saaaave meeee!!
                  Then you need another plan because you do stream it...
                  Try changing that second parameter to false and see if it does what you hope.
                  • 6. Re: Looping one 10 second sound file.. saaaave meeee!!
                    66jonez Level 1
                    hrmm yes i see that.  LOL...  told ya i m a newbie...  though i see its not as simple as just changing it to FALSE instead of true...  hrmm..
                    I do not want this file to start when they load the page..  just when they use the controls...  so I am really trying to keep with the script..
                    • 7. Re: Looping one 10 second sound file.. saaaave meeee!!
                      In addition to changing that to false, you should probably tame that 99999999999999999999.... loops value to something more realistic--start small and test for when it doesn't work anymore.  I'm don't think the function is geared to handle a number that size.
                      • 8. Re: Looping one 10 second sound file.. saaaave meeee!!
                        66jonez Level 1
                        WOW!  Yup.. the crazy 9s did it!  I was trying for an infinite loop...  thus the 9's,,,
                        i have it at 99999 and its loopin,....
                        nice work!
