0 Replies Latest reply on Apr 28, 2010 9:44 AM by Paul Reilly
    [svn:fx-trunk] 15789: * Package and class level javadoc for the flex2. linker, flex2.tools,
    Paul Reilly Level 1
      Revision: 15789
      Revision: 15789
      Author:   preilly@adobe.com
      Date:     2010-04-28 09:43:59 -0700 (Wed, 28 Apr 2010)
      Log Message:
      • Package and class level javadoc for the flex2.linker, flex2.tools,
        flex2.tools.flexbuilder, flex2.tools.oem, flex2.tools.oem.internal
        packages.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/CULinkable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/ConsoleApplication.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/FlexMovie.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/Linkable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/PostLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/SimpleMovie.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderApplication.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderLibrary.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/ApplicationInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Component.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/LibraryInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/PathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Script.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Toolkit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompiler.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationCompilerConf iguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ApplicationData.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/BuilderLogger.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ConfigurationConstants. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/EmbedUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/GenericMessage.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompilerConfigur ation.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryData.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConsole.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMLogAdapter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMPathResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMProgressMeter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/package.html
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/package.html
