3 Replies Latest reply on Apr 28, 2010 9:56 PM by MatHadder
    filterfunction
    GeorgeWS Level 1
      I have a RO that gets some data a few months of data. I want to show one month at a time. I made a slider that can change the months. So I have a bar chart that shows 4 people and when I move the slider it shows how well each person did for the selected month. Works great... but when the data is loaded it shows all months, when I move the slider it shows just the selected month and then works perfectly. How can it be filtered or refreshed from the start?
      public
      function handleQueryResult5(event:ResultEvent):void{
      myChart=event.result
      as ArrayCollection;
      myChart.filterFunction = sliderFilterFunc;
      private var months:ArrayCollection = new ArrayCollection([
      "January", "February", "March", "April", "May", "June",
      "July", "August", "September", "October", "November",
      "December"
      private function getSliderLabel(num:Number):String{
      return months.getItemAt(num-1) as String;
      public function getCurrentMonth():Array{
      return [new Date().getMonth()+1];
      private function slider_change(evt:SliderEvent):void {
      myChart.refresh();
      private function sliderFilterFunc(item:Object):Boolean {
      var minSlider:uint = slider.values[0];
      var result:Boolean=false;
      var pattern:RegExp = new RegExp("^"+myReport2.selectedValue,"i");
      if(!item[String("Status")].length
      || item[String(
      "Status")].match(pattern) &&
      (item.value == minSlider))
      result=
      true;
      return result;
        • 1. Re: filterfunction
          SpaghettiCoder Level 3
          creationComplete="onCreationComplete()"
          call a function that does the filtering either on the creation complete, or if you are retreiving data, as the last thing in your resultHandler for the returned data.
          • 2. Re: filterfunction
            GeorgeWS Level 1
            I was trying that for the resultHandler but that just gives me an error: 1009 cannot access property or method of a null object ref.
            I was adding myChart.refresh() to the resultHandler. When I take it out there are no errors.
            • 3. Re: filterfunction
              MatHadder
              Sounds like something the filter function uses is null when the results are first returned?
              private var _filterInvalid:Boolean = false;
              as ArrayCollection;
              _filterInvalid = true;
              this.invalidateProperties();
              override protected function commitProperties():void
              super.commitProperties();
              if( _filterInvalid && myChart != null && slider != null && slider.values != null && slider.values.length > 0 )
              myChart.refresh();
              _filterInvalid = false;
              Also, you might also want to have your filter function check that things are not null before using their sub properties.
