0 Replies Latest reply on Apr 28, 2010 2:36 PM by jmurphy67
    [svn:fx-trunk] 15797: Localization property file update 4.5.0.15795
    jmurphy67 Level 1
      Revision: 15797
      Revision: 15797
      Author:   jimurphy@adobe.com
      Date:     2010-04-28 14:36:14 -0700 (Wed, 28 Apr 2010)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_da. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_de. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_es. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fi. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fr. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_it. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ja. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ko. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nb. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nl. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_pt. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ru. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_sv. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ TW.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools_zh_TW.properties
