1 Reply Latest reply on Apr 29, 2010 11:15 PM by jfillman
    Data Type Between ArrayCollections
    jfillman Level 1
      I have object in my ArrayCollection that stores date as a number like this:
      {itemI
      D: 89012, Height: 50, Label: "Test # 1", Group: 0, Date: 1270450800000}
      I routinely pass an array item Object from one ArrayCollection to another (myACTwo.addItem(myACOne[4])), and as long as both ArrayCollections are within the same MXML file, the date field is passed correctly or if the data is being passed up to a parent, it also works: parentApp["myACTwo"].addItem(mySubAC[4]).
      However, if I'm passing the object from one MXML file down to an ArrayCollection in another file, I cannot seem to pass an individual Object without the Date field value changing. I'm passing the object as follows:
      myComponent.myACOne.addItem(myParentAC[4])). What happens is that the numerical date value of 1270450800000 gets translated into
      1272522491208, a completely different date. It actually is always changing it to the value for the current date and time, not a random date and time.
      I've also tried:
      var myObject:Object = myParentAC[4];
      myComponent.myACOne.addItem(myObject)
      with the same result.
      If I pass the entire array like this:
      myComponent.myACOne.source = myParentAC.source
      then then entire array is passed correctly, but I need to pass individual items, not the entire array.
      myComponent.myACOne.addAll(myParentAC) also causes the date to change.
