0 Replies Latest reply on Apr 29, 2010 2:47 AM by Paul Reilly
    [svn:fx-trunk] 15810: * Package and class level javadoc for the antTasks module and some
    Paul Reilly Level 1
      Revision: 15810
      Revision: 15810
      Author:   preilly@adobe.com
      Date:     2010-04-29 02:47:22 -0700 (Thu, 29 Apr 2010)
      Log Message:
      • Package and class level javadoc for the antTasks module and some
        other stragglers.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Corey (post commit)
      Tests run: checkintests
      Is noteworthy for integration: NO
      Modified Paths:
          flex/sdk/trunk/modules/antTasks/src/flex/ant/AsDocTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/AscTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/FlexTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/HtmlWrapperTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/ConfigAppendString.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/ConfigBoolean.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/ConfigInt.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/ConfigString.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/ConfigVariable.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/NestedAttributeElement.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/OptionSpec.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/RepeatableConfigString.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/DefaultScriptLimits.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/DefaultSize.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/FlexFileSet.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/Fonts.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/Metadata.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/RuntimeSharedLibraryPath.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/URLElement.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/LocalSource.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/URLSource.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/DependencyWalker.java
      Added Paths:
          flex/sdk/trunk/modules/antTasks/src/flex/ant/config/package.html
          flex/sdk/trunk/modules/antTasks/src/flex/ant/package.html
          flex/sdk/trunk/modules/antTasks/src/flex/ant/types/package.html
