5 Replies Latest reply on Apr 29, 2010 11:41 PM by hans-g.
    Editable Region in Template
    saintromain_j
      Can someone please help. I'm not a great web designer and I'm trying to build a new site to showcase my art. I created this .html file from my .dwt (all of this was designed .dwt file even though it is a start for my index page. I'm sure you will find a ton of things wrong with this page but (unless you find something else that I will really regret down the line) all I'm really looking for is how to turn the middle section of this page into an editable region. I've been trying with no success. I think it's just a matter of putting it in the correct spot. So if anyone can tell me exactly where in the code to put the editable region. (and tags for the region would be great, but beggers can't be choosers). So "what" and "where" to put it would be ideal, but "where", is essential.
      Link to page: http://24dpi.com/index_test.html
      Thank you in advance.
      Jeff
        • 2. Re: Editable Region in Template
          saintromain_j Level 1
          I appreciate the help and I will look through  those links when I get
          a chance tonight. But if anyone else would like to take a crack at this, let me know if you can give me an answer specific to my issue, and not just a link about editable regions. The reson for this is because I started to design my index page before creating a new html page from the template. So I foolishly started to design my index in my .dwt file. I would like all of my pages to look like the one I created, so I'm just lookin for a way to make the middle section of this page a editable region in my .dwt file so that I can create new html pages from the template w/o loosing everything I designed.
          link: http://24dpi.com/index_test.html
          • 3. Re: Editable Region in Template
            hans-g. Adobe Community Professional & MVP
            try this:
            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
            <html xmlns="http://www.w3.org/1999/xhtml">InstanceBegin template="/Templates/main2.dwt" codeOutsideHTMLIsLocked="false"
            <head>
            <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
            <title>now no further a Template</title>
            <style type="text/css">
            body  {
            background: #666666;
            margin: 0; /* it's good practice to zero the margin and padding of the body element to account for differing browser defaults */
            padding: 35;
            text-align: left; /* this centers the container in IE 5
            browsers. The text is then set to the left aligned default in the #container selector */
            color: #000000;
            background-color: #FFFCC3;
            font-family: Verdana, Arial, Helvetica, sans-serif;
            font-size: 100%;
            vertical-align: top;
            background-position: 35px;
            .thrColFix #container {
            width: 780px; /* the auto margins (in conjunction with a width) center the page */
            border: 1px solid #000000;
            text-align: left; /* this overrides the text-align: center on the body element. */
            background-color: #4C371A;
            padding: 0px;
            margin-top: 30px;
            margin-right: auto;
            margin-bottom: 0;
            margin-left: 30px;
            right: 35px;
            .thrColFix #sidebar1 {
            float: left; /* since this element is floated, a width must be given */
            width: 150px; /* padding keeps the content of the div away from the edges */
            font-family: Georgia, "Times New Roman", Times, serif;
            font-size: 22px;
            line-height: 25px;
            color: #FFFCC3;
            letter-spacing: -3px;
            font-weight: bold;
            height: 100%;
            padding-top: 15px;
            padding-right: 10px;
            padding-bottom: 15px;
            padding-left: 20px;
            .thrColFix #sidebar2 {
            float: right; /* since this element is floated, a width must be given */
            width: auto; /* the background color will be displayed for the length of the content in the column, but no further */
            padding: 0; /* padding keeps the content of the div away from the edges */
            color: #4C371A;
            .thrColFix #mainContent {
            margin: 0 200px; /* the right and left margins on this div element creates the two outer columns on the sides of the page. No matter how much content the sidebar divs contain, the column space will remain. You can remove this margin if you want the #mainContent div's text to fill the sidebar spaces when the content in each sidebar ends. */
            padding: 0 10px; /* remember that padding is the space inside the div box and margin is the space outside the div box */
            font-size: 10px;
            font-style: normal;
            line-height: 20px;
            font-weight: normal;
            color: #FFFCC3;
            letter-spacing: 2px;
            .fltrt { /* this class can be used to float an element right in your page. The floated element must precede the element it should be next to on the page. */
            float: right;
            margin-left: 8px;
            .fltlft { /* this class can be used to float an element left in your page */
            float: left;
            margin-right: 8px;
            .clearfloat { /* this class should be placed on a div or break element and should be the final element before the close of a container that should fully contain a float */
            clear:both;
                height:0;
                font-size: 1px;
                line-height: 0px;
            .style1 {
            font-size: 12px;
            letter-spacing: 7px;
            margin: 0px;
            a:link {
            color: #FFFCC3;
            text-decoration: none;
            a:visited {
            color: #FFFCC3;
            a:hover {
            color: #E0D765;
            a:active {
            color: #FFFCC3;
            .style4 {
            font-size: 18px;
            color: #E0D765;
            #apDiv1 {
            position:absolute;
            left:210px;
            top:23px;
            width:12px;
            height:538px;
            z-index:1;
            line-height: 10px;
            color: #E0D765;
            </style>[if IE 5]>
            /* place css box model fixes for IE 5* in this conditional comment */
            .thrColFix #sidebar1 { width: 180px; }
            .thrColFix #sidebar2 { width: 190px; }
            </style>
            <![endif][if IE]>
            /* place css fixes for all versions of IE in this conditional comment */
            .thrColFix #sidebar2, .thrColFix #sidebar1 { padding-top: 30px; }
            .thrColFix #mainContent { zoom: 1; }
            /* the above proprietary zoom property gives IE the hasLayout it needs to avoid several bugs */
            </style>
            <![endif]
            name="head"
            </head>
            <body class="thrColFix">
            <div id="apDiv1">
              <p>.<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
              .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
            .<br />
              .<br />
              </p>
            </div>
            <div id="container">
              <div id="sidebar1">
                <div id="navigation">
                  <h3 class="style1">NAVIGATION</h3>
                </div>
                <h3><a href="index.html">Home</a></h3>
              <h3><a href="skateboardart.html">Skateboard<br />
                Art</a></h3>
              <h3><a href="aluminumhangers.html">Aluminum<br />
                de Signs</a></h3>
              <h3><a href="about.html">Story</a></h3>
              <h3><a href="contact.html">Contact</a></h3>
              <h3> </h3>
              <h3 class="style1">PORTFOLIOS</h3>
              <h3><a href="illustration.html">Graphic<br />
                Design</a></h3>
              <h3><a href="graphicdesign.html">Illustration</a></h3>
              <h3>
                end #sidebar1
                <span class="style4">© 1981-present<br />
                </span></h3>
              </div>
              <div id="sidebar2">
                <h3 align="center"><img src="LogoStudiosLampBrown.jpg" width="170" height="600" /></h3>
                <div align="center">
                  end #sidebar2
                  </div>
              </div>
              <div id="mainContent">
                <h1> New Site Launch</h1>
                <p>Welcome to our new website. We hope you enjoy the new look and find it easy to navigate. <img src="board350px_sidewalk.jpg" alt="sidewalk skateboard" width="100" height="360" align="left" /></p>
                <h2>Latest Artwork </h2>
                <p>To the left you will find the first design in our Hybrid Series. No, it won't save you a ton of miles per gallon, it's rather a mix between our Skateboard Art and the Aluminum de Signs. This one is called &quot;<em>Sidewalk Strut&quot;. </em>And, check back soon because there will be more to follow.<br />
                  <br />
                </p>
                <h1>Main Content </h1>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam,  justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam  ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo  porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis  ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean  sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at,  odio. Donec et ipsum et sapien vehicula nonummy. Suspendisse potenti. </p>
                <h2>H2 level heading </h2>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam,  justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam  ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo  porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis  ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean  sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio.<br />
                  <br />
                </p>
                <p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam,  justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam  ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo  porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis  ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean  sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio.</p>
              end #mainContent</div>
              This clearing element should immediately follow the #mainContent div in order to force the #container div to contain all child floats<br class="clearfloat" />
            end #container</div>
            </body>
            </html>
            Hans-G.
            • 4. Re: Editable Region in Template
              Thanks!
              That helped me figure it out. Now, can we delete this thread? I'd rather not have the html just out in the open like this. I didn't see an option to delete. If you can that would be great.
              Thanks again for all the help. Sorry to be a pain.
              Jeff
              • 5. Re: Editable Region in Template
                Hi Jeff,
                I'm pleased that I could help you. To my knowledge you/we can't delete a thread, sorry.
                Hans-G.
