1 Reply Latest reply on Apr 29, 2010 7:41 AM by Mike Sofa
    Scripts menu
    Sashikala Balasubramanian
      To execute a script many times we had to go to File menu ->Scripts and then select the script.
      Is it possible to assign a short cut key to each script in the script menu. This will make the job easier.
      Is there any method to execute a script with not much difficulty.
      regards,
      Sashi
        • 1. Re: Scripts menu
          Mike Sofa Level 2
          As of Illustrator CS4, the answer is no.
          However, you can create an action which includes a script using "Insert Menu Item..." and assign an f-key to the action. But the action will "forget" the script step every time Illustrator is restarted. As of CS4.
          Or, you can assign a shortcut to the sub-menu "Other Script..." command, and it will bring up a dialog box which can be navigated using the arrow keys. At least you can stay on the keyboard instead of pointing and clicking on a menu.
          We'll have to wait just a little bit longer to see about CS5.
          Hope this helps.
          Mike D.
